Message 11 of 19
Re: New Install
It doesn’t display any stats when connected to the Openreach modem, so I had to connect it directly to get the stats from the technical log.
Expert
Message 12 of 19
Re: New Install
yes sorry my bad i see that now.
Message 13 of 19
Re: New Install
It is unusual for the speed in the test socket to be less than another socket. When connected to test socket did you check fir a dial tone at all your extension sockets wether in use it not
Message 14 of 19
Re: New Install
We have no extensions in the house to test so probably adds to the mystery really.
Message 15 of 19
Re: New Install
Speed seems to have dropped. Connection timer on the hub has also reset. 😞
Message 16 of 19
Re: New Install
Went to chat with BT to see why my speed had dropped and they say I’m now getting 32.2Mbps. But it’s over the 32Mbps minimum so they won’t do anything until it drops further. 😭
Message 17 of 19
Re: New Install
bear in mind it is connection speed that has the guarantee not the download speed so at present you are above the monimum according to the btspeedtester profile
Message 18 of 19
Re: New Install
Yes very true. It was the BT chat rep that said my connection speed was at 32.2Mbps. I haven’t actually run the test again to double my ip profile to confirm what they said.
Message 19 of 19
Re: New Install
So I’ve been back on chat with BT and they’ve refreshed my line and connection. I’m guessing they’ve not actually done anything? They won’t book an engineer until I’ve waited between 24-48 hours for my line to stabilise.
I ran a test this morning before I left for work that put my ip profile at 31.7Mbps. I can’t remember the exact number.
Where do I go from here?
