JTilbury91
Message 1 of 23
New Installation, No Connection
Hi all,
Got a confirmation text and email yesterday saying that my infinity 2 is now active.
Plugged HH5 into master BT socket as directed and turned it on.
Cycles through lights and eventually settles on a solid orange power light with intermittent orange broadband icon. The orange broadband icon cycles on and off at a rate of about once a minute.
I can connect via wireless to the router and was able to access the logs below.
Can anyone help? Is this an issue at my end or has my line simply not been activated?
1. Product name: BT Home Hub
2. Serial number: +068543+NQ50105203
3. Firmware version: Software version 4.7.5.1.83.8.204 (Type A) Last updated Unknown
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 00:10:05
6. Data rate: 14993 / 39993
7. Maximum data rate: 32424 / 96651
8. Noise margin: 18.4 / 22.0
9. Line attenuation: 8.2 / 9.7
10. Signal attenuation: 8.1 / 9.7
11. Data sent/received: 9.9 MB / 4.3 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: No
14. 2.4 GHz Wireless network/SSID: BTHub5-XRJ3
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID: BTHub5-XRJ3
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 44:e9:dd:51:b6:f0
24. Modulation: G.993.2 Annex B
25. Software variant: AA
26. Boot loader: 1.0.0
22 REPLIES 22
Message 2 of 23
Re: New Installation, No Connection
it sounds like you are not yet activated call 08001114567
JTilbury91
Message 3 of 23
Do the logs I have posted confirm that the line, while not active, is functional?
I ask because the previous tenant had some bizzare arrangement of cables around the master socket and I was concerned that my line itself may have been damaged.
Thanks for the quick response!
Message 4 of 23
Something is working as hub shows 4+gb downloaded
JTilbury91
Message 5 of 23
Yep, that was my assumption as well; it also gives a figure for DSL uptime.
I will ring BT as advised.
Message 6 of 23
Try ONE factory reset of the homehub by pressing a pin into the recess button on the rear for about 20 seconds.
JTilbury91
Message 7 of 23
Tried the factor reset as advised.
The figure of 4.3GB received was immediately present, surely this should not have persisted through a factory reset?
5. DSL uptime: 0 days, 00:03:05
7. Maximum data rate: 32313 / 96287
11. Data sent/received: 11.8 MB / 4.3 GB
13. BT Wi-fi: No
Message 8 of 23
Did you use the factory reset as described here.
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-home-hub-to-its-factory-...
  1. Find the recessed "Reset" pinhole button on the back of your Hub
  2. Using a paper clip or similar press the button and hold for 20 seconds. Your Hub lights will go out and your Hub will restart
  3. Wait a few minutes for the Hub lights to settle. The central Power light will go blue and the Broadband light will be off
lines_man
Message 9 of 23
You're getting a down/up speed so the modem parts obviously in sync.....
Do a hard reset of the HH5, if that doesn't work either you have a fluffed hub or there's a problem with your profile.....
Deathtrap3000
Recognised Expert
Message 10 of 23
You have been set up wrong. Your profile is 40/15 which means a provisioning issue or the engineers connected you to the wrong port.
