geoff51
Message 1 of 5
New Smart Hub
I have just ordered the new BT Smart Hub to replae my ageing Home Hub 3 which is playing up. What i need to know is 1. does it just plug into the white Openreach box like the 3home hub. 2. will it have a new SSID and wireless key.  I hope you can help me as it is being delivered on Wednesday.
Geoff
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: New Smart Hub
Hi @geoff51,
You don't need to connect the new Smart Hub to the Openreach Modem, this is because it already has the modem built in.
The new Hub will have its own SSID, you can change this by login into the Hub Manger. You will need to connect all devices to the new SSID once you set up your new hub.
PaddyB
geoff51
Message 3 of 5
Re: New Smart Hub
Thanks Paddyb
do you just plug it straight in to the top socket on the wall and dispense with white box completely? does it come with installation instructions and cani connect using wps?
Geoff
Message 4 of 5
Re: New Smart Hub
Yes, just plug the lead that currently goes to the modem DSL socket into the DSL socket of the new hub, plug and play. Yes it supports wps.
geoff51
Message 5 of 5
Re: New Smart Hub
Just to let you know I have recieved and installed the new Smart hub with help from these forums. It was really easy and took less that 30 mins to install and connect 5 items to the hub. I am now getting 52mbps most of the time and it was definitely worth the £50 it cost as my old HH3 was shot.
Geoff
