rjm7
Message 1 of 20
New account speed
Hello there
i had an infinity install the other day and speed seems somewhat down from the 38Mbit/9.5Mbit speed i was hoping for
Can anything be done? The Hub Manager report.
1. Product name:BT Home Hub
2. Serial number:+068543+NQ55020073
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated Unknown
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 11:00:44
6. Data rate:7104 / 28894
7. Maximum data rate:7122 / 29991
8. Noise margin:6.0 / 5.9
9. Line attenuation:39.3 / 21.0
10. Signal attenuation:36.9 / 20.0
11. Data sent/received:153.2 MB / 2.2 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:No
14. 2.4 GHz Wireless network/SSID:BTHub5-KN73
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-KN73
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:84:a4:23:0c:8c:f6
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
19 REPLIES 19
Message 2 of 20
Re: New account speed
Hi and welcome. Could you please pop your number into here https://www.btwholesale.com/adslchecker/ and paste the results for us. Remove your number before posting them 🙂
Message 3 of 20
if it was self iinstall are you using the test socket with a new filter?  test socket.jpg
rjm7
Message 4 of 20
I'm not sure how it won't let me right click to save the text.
rjm7
Message 5 of 20
It wasn't self install just using the filter supplied by the engineer
Message 6 of 20
It should do, I can do it on mine. Failing that, could you take a screenshot and post that, editing out the information such as your phone number in Paint beforehand.
rjm7
Message 7 of 20
 http://oi68.tinypic.com/345hb29.jpg
i uploaded a picture to tinypic, forum wouldn't let me display for it some reason
Message 8 of 20
Yeah something isn't right. If possible, could you remove the front plate from your master socket and behind it should be another socket (as displayed above). If you connect a microfilter into that socket and then connect your router to the filter, that will eliminate any of your internal wiring from the circuit. Once you've done that, post the router stats here again as you did in your original post and we'll see if it's made any difference. If it makes no difference, you'll need an engineer visit.
Message 9 of 20
if you connect to test socket can you just check that none of your extension sockets have a dialtone - just to check internal wiring is wired as expected
rjm7
Message 10 of 20
here is the result from the master test socket
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
5. DSL uptime:0 days, 00:12:48
6. Data rate:9995 / 40000
7. Maximum data rate:16288 / 52756
8. Noise margin:10.1 / 8.2
9. Line attenuation:31.4 / 21.6
10. Signal attenuation:31.2 / 19.5
11. Data sent/received:19.4 MB / 79.3 MB
13. BT Wi-fi:No
