Message 1 of 2
New build connection
Hi I’m hoping I’m in the right place here, we’re due to move into a new build in a couple of months, I’ve tried asking the developer ( small company) about wether there is any fibre being installed, the response I got was its up to the home buyers to sort that out.. I know there is fibre in and around the area of the development, this is a small area of waste land behind some existing properties consisting of 9 dwellings. Can someone point me in the right direction of finding out what services will be available or if it’s a requirement of the developer to install some kind of connection ready. I know building regs changed in dec 2022 requiring all new builds to have gigabit access, but I believe because this development started before the regs changed then they do need to adhere to the new requirements. This infuriates me tbh.
1 REPLY 1
Message 2 of 2
Re: New build connection
It shouldn’t be up to the purchaser but the developer to arrange some sort of landline service , it doesn’t necessarily have to be Openreach, but OR do have the largest network and work with developers of all sizes , provided the developer gets in touch early in the build, OR will build network into the property ready for occupation, but ( obviously ) OR can only respond if the developer gets in touch.
If your developer hasn’t made any arrangements with a network provider ( as you are posting on a BT forum , it would be Openreach as they are the only network provider that BT use ) then it’s very unlikely that you will have access to Openreach based services, FTTP or copper based FTTC/ADSL.
If the surrounding area is served by telegraph poles , it may be possible to reach the new properties if there is line of sight from the pole and it isn’t too far to span a wire, but that may not be possible, and it’s likely that the addresses, once they are registered with the appropriate authorities, won’t be matched against any usable network should you enquire with BT .
You should get the developer to make arrangements to get service provided , asking for ‘fibre’ may be confusing, ask what telephony arrangements are in place.
