Mwallwork
Message 1 of 20
New build house no Bt fiber?
Hi I’m buying a new house . It’s a new build estate just off an existing street that has fibre. I’ve checked my new post code hd9 5as and it shows that it’s on a cabinet that’s fibre enalbed and I checked the neighbouring existing houses that are just across the road and they are on the same cab and can order fibre. As there will be no phone line at new property is it just a matter that I have to order base broadband get connected then upgrade ?
19 REPLIES 19
Message 2 of 20
Re: New build house no Bt fiber?
Enter your address and post results. Remember delete address https://www.btwholesale.com/includes/adsl/main.html
Mwallwork
Message 3 of 20
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available --
ADSL Products
Availability Date
WBC ADSL 2+ Up to 9 -- -- Available --
ADSL Max Up to 6.5 -- -- Available --
WBC Fixed Rate 2 -- -- Available --
Other Offerings
Availability Date
ADSL Multicast -- -- -- Available
Mwallwork
Message 4 of 20
This is what it says but I had to do address checker no postcode . This is telling me fibre is avaible but I can’t order it it online why?
CJT80
Expert
Message 5 of 20
@Mwallwork
Because of the format it's hard to tell, but I think only Fibre on Demand is available.
Can you try getting a screen shot? like this:
Note under VDSL mine say's FTTP on Demand.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Mwallwork
Message 6 of 20
How do I attach a screenshot here?
Mwallwork
Message 7 of 20
But you are right it say FTtp only no vdsl however cabeninet 3 at Meltham is accepting orders and all surrounding properties including the house across the road can order fibre
Mwallwork
Message 8 of 20
When I go on the open reach site is says cabinet 3 Meltham and states fibre is available to cabinet but I cannot order just yet . If a change the address to across the road it’s avaiable for order . What does this mean ?
CJT80
Expert
Message 9 of 20
When you hit reply,
Look above where you type for Photos (with a symbol of a camera) click on that
Kind Regards
CJT80
Mwallwork
Message 10 of 20
Doesn’t give me that option but I’m on a iphone
