Message 1 of 2
New full fibre 900 install, but upload speed capped at 50Mbps
I've just had my copper replaced with fibre, and subscribed to the Fibre 900 package that should get 900 Mbps download / 110 Mbps upload.  However, when testing (via ethernet) I reliably get just over 900 Mbps download but my upload seems to be capped at 50 Mbps.  I get this via the Smart Hub 2 or when connecting directly to the ONT.
I can see on the forum others have had the same issue and it has been resolved by the forum staff.  I'm hoping for the same. 🙂
1 REPLY 1
Message 2 of 2
Re: New full fibre 900 install, but upload speed capped at 50Mbps
if you read the majority of posts the capped upload usually resolves itself in a few days after installation without any intervention
