Message 1 of 19
New house, •Huawei: Openreach modem fitted, but I have a Hub 6, What do I do?
I just moved into a new house 3 weeks ago,
there is a Huawei: Openreach modem fitted, but I have a Hub 6 on an infinity package, how do I set this up?
Does the openreach box need turning off? and simply plug the hub 6 into the double socket without the filter?
Seems odd to not us the openreach box if that is the case, as yet we have no broadband on the hub 6 only the flashing purple light?
No idea what to do and BT have not been very helpful, i'm very confused. HELP.
18 REPLIES 18
Message 2 of 19
Re: New house, •Huawei: Openreach modem fitted, but I have a Hub 6, What do I do?
The Hub6 has a built in modem rendering the Openreach modem superfluous. Just remove the modem and connect the DSL socket on the Hub to the same phone socket that the modem was previously connected to.
Message 3 of 19
Thanks for the reply.
Seems crazy Opereach are fitting these things in new houses if they are not needed.
Is it possible the open reach box is stopping the home hub 6 from working as I'm not enjoying the purple flashing light?
Message 4 of 19
Just to be clear, this is an FTTC installation and not FTTP? I.e the Openreach modem plugs into the phone socket and is not an ONT with a fibre connected to it.
Message 5 of 19
Does the 'modem' look like this?
Image result for huawei ont
Message 6 of 19
more like this. Plus it has built in battery into the wall.
Message 7 of 19
In which case it isn't needed and should be removed. Just connect the hub in its place. No idea why a new build should have a modem fitted, they haven't been fitted for a number of years.
Message 8 of 19
It definitely doesn't have a fibre optic cable connected to it though?
Message 9 of 19
I don't believe so, BT seemed unconcerned when I said there was an openreach modem in the house already and were desperate to send me a home hub 6. even though I already had one from the last property.
Sage
Message 10 of 19
If the modem has a battery back up then that sounds like FTTP and shouldn't be touched.
To would need the replacement Hub 6 as it will have a WAN port to connect to the ONT  (modem)
