robartist
Message 1 of 8
New install superfast fibre 2 and phone line in big Victorian house
Hello
I wondered if some of you could please give me some advice.
Currently on Virgin. But have moved to BT for both fibre broadband and new telephone line. Install in October.
I understand that the fibre is fibre as far as a 'cabinet' and then on to my house.
Questions:
1 There is a telephone pole outside my house. With an old line from it to my house. Will both the internet and phone come from that pole?
2 Locating the master socket. Where is it best to locate this?
3 Locating the BT smarthub. Where is the best place to locate this.
4 Will the installation engineer let me have the smarthub in a different place to the master socket and run a cable between the two?
5 I want to have access to the ethernet ports on the back of the smarthub. This causes problems with location.
6 Currently I have three phone sockets. Will the engineer rewire these from the new master socket (or whatever it's called)
7 What is the preferred routing for the cable from the telephone pole to the middle of the house? From pole to house at eaves level then down face to cellar then up in an appropriate place?
Forgive me asking stupid questions. I have no idea about these things and don't want to panic on the day and choose the wrong places.
Thanks for any help
7 REPLIES 7
Message 2 of 8
Re: New install superfast fibre 2 and phone line in big Victorian house
@robartist wrote:
Hello
Questions:
Only you can decide that
Only you can decide that based on how you intend to use it.
Any internal wiring is your responsibility, the installation engineer will only provide the master socket. You can place the hub in any location you wish.
No
Whatever is the easiest for the engineer basically, he will expect to provide the master socket on an external wall i.e pole to eaves down face and through wall at ground level. If there is currently a cable from the pole he will just re-use that.
Thanks for any help
robartist
Message 3 of 8
Many thanks Licquorice, very helpful
Following on....
1 If I want to have the hub some distance from the master socket is it a case of using cat5e and what connectors would I need.
2 The cable from the pole is very old. About 35 years old I think. Will they replace that?
3 What is best way to connect other phone sockets to master socket? Will the engineer wire them into the back of the master socket or would I need to take a splitter out of the front phone socket?
4 Is it generally the case that BT has a problem in a big house ?
5 The logic of the installation position is problematic. IF the smart hub is good enough for the whole house then it can be placed fairly centrally. But if it isn't then it would be more logical to place it so that it performs well for one area and then use repeaters or whatever elsewhere.
6 Can I plug another wifi thing into one of the ethernet ports and have a better signal in another part of the house - I realise it wouldn't automatically switch.
Many thanks again
Message 4 of 8
Following on....
You can, but CW1308 would suffice. Just wire from the data extension terminals in the master socket to an RJ11 socket where you require the hub to be sited.
Depends on its condition, it will probably be fine.
As stated previously, the engineer will just provide the master socket, you will have to provide any extension wiring. This simply connects to the removable faceplate of the master socket.
Openreach, not BT, don't have a problem as internal wiring is not their responsibility.
Agreed, but don't use repeaters, either use homeplugs or cabled wireless access points. Repeaters are a poor solution.
Yes, as described above, you can have multiple wireless access points simply connected via your mains wiring with homeplugs. https://shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-multi-kit-084289-BVFH.html  for example
robartist
Message 5 of 8
Many many thanks Licquorice, again!
OK I feel as though I am sort of getting somewhere though I am in the horns of a dilemma in terms of location, due to not being able to know how good the location is until it has been installed.
1 my question about problems with a Victorian house was badly worded by me. I meant in terms of signal strength. In other words, will a smart hub centrally located on the ground floor in a Victorian house reach the whole house or am I likely to need other methods of extending it - eg as you mentioned homeplugs.
2 You say......." This simply connects to the removable faceplate of the master socket.". Do you mean I remove the faceplace and connect the cables for the two sockets into the back of it - using ?? those push in connections IDC?
3 When we went over to fibre a long long time ago before our current supplier the installation engineer cut the BT phone line. And used the remains of part of it for our phone from the box to the house. Will all of that need replacing. In other words will the engineer take new cable from the eaves down the face, around the corner and through the wall as per current installation.
4 You say "You can, but CW1308 would suffice. Just wire from the data extension terminals in the master socket to an RJ11 socket where you require the hub to be sited.". But I've been given a big reel of cat 5e (neighbour bought too much for his system). So are the data extension terminals in the master socket IDC. Then I need to go to an ordinary RJ11 socket or is it a special kind for the BT router.
5 How much cable from the BT router to the master socket is it reasonable to expect the engineer to supply?
6 Joining cat5e. As a result of the router going in a place which is not ideal for my current ehternet cables I need to join them. Is it ok to solder them or does that cause signal problems (?? a thermocouple effect due to different metals??)
7 Currently I have an ethernet cable from Virgin hub to back of the house where I have a TP-link thing just used as wifi transmitter. Can I still use that arrangment
8 You suggest the plug in extenders. Are they better than the BT mesh system with disks?
Many thanks again for all of your help. You've been brilliant!
Message 6 of 8
You will probably need some form of extender, you won't really know until you try it.
Can't really comment on that, without knowing exactly what has been done. The engineer will do whatever is required.
Data extension are IDC and any RJ11 socket will suffice.
Not sure I understand the question, the connection from the master socket to the hub is by means of the RJ11 - RJ11 lead supplied with the hub.
Should be ok
I have no experience of the disk system so I'm afraid I can't comment.
robartist
Message 7 of 8
Thank you so much. You've helped me a lot. I was rather worried about the install - we're pensioners and short of dosh so we didn't want to have to pay for more work to be done at a later date if the initial install wasn't good.
Just for information our new hub does't come with a RJ11-RJ11 cable. I guessed - perhaps wrongly - that the engineer would make one up on site.
Again thank you
Very best wishes.
Message 8 of 8
if you are getting superfast fibre FTTC then the hub pack should include an RJ11 cable (modem) to connect your hub dsl socket to the dsl socket on the master socket
