smurphy
Message 1 of 14
Newsgroups infinity option2
Option 2 unlimited "re contracted"
I was Happily getting a throughput of just a tickle over 9meg from newshosting and easynews. Since last weekend I have been struggling to get above 6.
I also think my hh is in its way out, not looking for a hh4 just a working hh3. Anyone else having issues?
13 REPLIES 13
Message 2 of 14
Re: Newsgroups infinity option2
newsgroups are fine for me - no restrictions and never has been
woodland81
Message 3 of 14
I have issue with newsgroups too.
speedtest shows i should have 50mb, but since before the weekend, im struggling to get a max of 20-30mb.
I also have un unchangeable IP
Distinguished Guru
Message 4 of 14
Giganews full speed for me
If not, I'll try again 🙂
Distinguished Guru
Message 5 of 14
You will also be limited bt what your News provider can give you, that might not be 50Mb.
toekneem
(EASBF)
smurphy
Message 6 of 14
Hi mate,
I have been getting a steady 90mb from easynews and newshosting.. I have had a 10mb drop since last sunday.
I am on unlimited usage for both and re signed bt last tuesday as I got the tv packages.
willp2003
Newbie
Message 7 of 14
I've had problems for the last week as well, resulting in quarter or half speed. I'm using newshosting. I'm starting to think that BT are throttling the SSL ports. If I change to another server port it goes back up to a good speed but not full speed (7-8MB/s), but these are not SSL ports, which I would prefer.
woodland81
Message 8 of 14
yes mines newshosting too, used to get 50mb, now 15-20mb.
what the point of infinity if they are throttling us, not worth the £26
Distinguished Guru
Message 9 of 14
How can it be BT throttling you when I get full speed on Giganews?
graystreet
Message 10 of 14
I'm using Giganews using SSL port 563 and max out my connection at 56Mb/s constantly.
Last month, to try to reduce costs, I did try NewsDemon for a couple of weeks and couldn't reliably get more than 30Mb/s out of their servers. I decided to stay with Giganews !!
I would suspect the News Provider rather than BT personally.
