nidriks
Message 1 of 13
No Infinity for 9 days - information sorely lacking
I've had no infinity in BH4 for 9 days now and I just wanted to guage if anyone else was in the same boat.
Every day I see a time for the problem to be fixed, and every day that deadline is not met. I've raised a fault which BT somehow tagged with 'complete' when it wasn't, and I had to raise a new fault.
Every method of communication (the intro message when you ring, the fault tracker, my raised fault) gives me a different time for the fault to be fixed, my attempt to complain got me nowhere, and I'm starting to lose all will to live with this dreadful companies poor customer service.
I just want answers.
I started looking at new broadband providers yesterday because I am just sick of this situation. I then find myself wondering if I'd even get broadband from another provider or whether this apparent fault would cause problems with that.
I've considered contacting the ombudsman to see what my rights are and whether I can demand BT should have fixed this by now.
In my mind 9 days is too long when I am paying a good amount of money for a service, and the fact I get next to no information is not good enough. I've been with BT many years and I like to think I am a loyal customer. So why am I treated this way?
12 REPLIES 12
Moderator
Moderator
Message 2 of 13
Re: No Infinity for 9 days - information sorely lacking
Hi @nidriks,
I'm sorry to hear about the problems you have trying to get your fault fixed. As you can post here I'm assuming you might be able to use our live chat service. You can reach the tech team at the following link: BT Tech Chat
That team should be able to give you an update and let you know what's happening.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
nidriks
Message 3 of 13
Thank you @DanielS, I will try that tomorrow when I have a free day. I have spoken to three other customer service people and one said that they would have the only information available, but I guess it is worth a go.
I have internet only because I went out and bought a dongle from my mobile provider. The way BT are going about getting this fault fixed I'm thinking I will get through the 12GB of allowance on the dongle easily.
Sorry, this fault is making me sarcastic. Thanks for taking the time out to reply. I appreciate it.
Moderator
Moderator
Message 4 of 13
You are very welcome @nidriks.
Can you click on my user name and then click on contact the mods? It'll send us through a ticket to look into your account. It'll take us approximately 5 working days, at this time, to pick it up but if you still have issues we'll own the issue until it's fixed.
DanielS
Kudos”Kudos”
nidriks
Message 5 of 13
Thanks for your help @DanielS. I have done what you said and contacted the mods.
I actually just got a message from BT to say that the problem has been fixed, but I plugged in the hub and I still have no connection. I think it may have been just a delayed message from the fault someone changed to 'completed', because the fault effecting my area is still active on the fault tracker.
I have to go to work now, but what I will do in the morning is plug in my old home hub and see if that works. It was a thunderstorm that knocked the internet out, and I guess it's possible the fault may have been fixed but my hub 5 sustained damage.
I'll try that chat option you suggested in the morning too.
Thanks for all your help.
nidriks
Message 6 of 13
Thanks to the suggestion of @DanielS I am back online. I spoke to tech chat and they sent me a new Home Hub. The only problem is I am only getting speeds of about 35 Mbps on Infinity 2. I was getting 75 before the outages.
At first I thought the problem was still apparent because the hub was showing an orange light, but it must have taken a while to warm up before going to a blue light.
Am I seeing after effects of the outages in my speed?
Message 7 of 13
Can you post the connection stats from the home hub?
nidriks
Message 8 of 13
@Webby
Sure:
1. Product name:BT Home Hub
2. Serial number:+068543+NQ43226290
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 05/08/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 02:35:06
6. Data rate:16997 / 38274
7. Maximum data rate:32025 / 95274
8. Noise margin:13.6 / 21.6
9. Line attenuation:7.1 / 9.3
10. Signal attenuation:7.1 / 9.3
11. Data sent/received:264.0 MB / 4.9 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:No
14. 2.4 GHz Wireless network/SSID:BTHub5-T6Q2
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-T6Q2
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:c8:91:f9:52:d4:b0
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
I was talking with a friend and he suggested it might be because my IP has been unstable and it may just need time to revert to a more accurate speed.
nidriks
Message 9 of 13
I'm tempted to say I've been incorrectly moved to Infinity 1. I ran a BTWholesale speed test and it says my max achievable speed is 37.05 Mbps. MyBT does say I am on Infinity 2 though.
 Download Speed
 35.64 Mbps
0 Mbps37.05 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 35.64 Mbps
 Additional Information:
 IP Profile for your line is - 37.05 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 12.95 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 12.95Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Message 10 of 13
You're on Infinity 2, the upload profile confirms that.
You've likely had a dropping connection and as a result your noise margin has been increased (to 21db which is very high).
Leave it alone and the speed should gradually return over the next few weeks as the noise margin reduces (providing the line is stable).
