daviehop
Message 1 of 8
No Internet Available.
Have a solid blue light on my Homehub 5a, then this message appears,   " No Internet Available" does the screen shot give us any information ? is this a Hub problem ?wire lan port.png
7 REPLIES 7
pippincp
Sage
Message 2 of 8
Re: No Internet Available.
Do you have a dial tone on your phone line?
daviehop
Message 3 of 8
I have a cordless landline phone incoming and outgoing calls are fine.
daviehop
Message 4 of 8
Just done a quiet line test on 17070 and there is crackling on the line ?
Devon_Dave
Distinguished Guru
Message 5 of 8
Can you use a corded phone into the test point of your main telephone socket? If it's still noisy there You will need to report this to BT as a noisy line, don't mention the broadband.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
daviehop
Message 6 of 8
will have a hunt for a corded phone, is the above screen shot telling us there is something wrong with the phone line ?
pippincp
Sage
Message 7 of 8
No, it is just that the phone line is a logical place to begin diagnostics. Any phone line problem will have an effect on your broadband connection.
You have mentioned cracking on the line, once tested from the test socket to rule out any internal wiring report a line fault.
daviehop
Message 8 of 8
Thanks will do.
