Matt-S
Moderator-Retired
Message 71 of 80
Re: No broadband for nearly 2 weeks — fix date keeps changing
Hi @Boss89,
I can see since my last post @NeilO has offered out help on your case and sent you a private message. I have checked our queue and I don't see your reply, have you completed the template and sent it back into us?
@NeilO wrote:
Hi @Boss89, Welcome to the community and thanks for posting, I'm really sorry your broadband isn't working at the moment, I appreciate the inconvenience this can cause. I don't believe anyone was trying to undermine your situation with the questions they were asking as checking the number is correct on the line is one of the things to do after a line has been reconnected when a cabinet is damaged as it's not uncommon for the line to be connected to the wrong number which in turn means the broadband won't work.
I've sent you a private message so you can get in touch and we'll be happy to check the fault status and find out what's happening, we're quite busy at the moment so it will take a couple of days for us to respond.
Matt
imjolly
Message 72 of 80
Re: BT Wgon't fix my issue or let me cancel
@Boss89 wrote:
Why is it that when we spoke to am openreach engineer "who identified himself as such" he said it's on BT since it's down to them to configure it?
as I posted BT Retail do no reconfigure the phone line that is openreach and I suggest what you were told was just to stop you asking more questions and blame someone else.  That way openreach engineer walked away
pompey1898
Recognised Expert
Message 73 of 80
Hi @imjolly & @Matt-S ,
I can't work out where this guy, I assume he is male, is coming from.  He never responded with any answers to the questions members asked and it would appear as though he never replied to the 3 offers of help from the mods.
Since he said a few posts back that he was switching ISP I can't see any way the community can help him.
Boss89
Message 74 of 80
So far, all I was asked to do was dial 17070--something I did which hasn't worked. I'm still being charged for a service I'm not receiving. The engineer I spoke to didn't say anything of the sort and I resent your reply. He said himself he was sent on a wild goose chase and that nobody has been asssigned to work on my fault.
Boss89
Message 75 of 80
They called us today and now the fix date is "unknown since we need to connfigure the G-fast in your area". How will I explain this to my university or employer?
iniltous
Guru
Message 76 of 80
When asked ( and you were asked to confirm ) you have said you are on exchange based ADSL , so what has Gfast  ( a service delivered from a street cabinet ) got to do with your lack of a broadband service.
Myself, ( and I dare say others on here)  , have attempted to help and diagnose your problem with the little information available, ( it’s probable we have  a little more understanding of how the network fits together than some ) but  the information requested of you has been asked the least technical way, but if you are , were , or were in the process of being moved onto Gfast, that makes an enormous difference to diagnosing whatever your issue is , being on Gfast isn’t the same as being on ADSL, perhaps if you are interested in a resolution ( unless you your sole aim is to move ISP and challenge any termination charges, giving accurate info , or asking for clarification if some requests for info are unclear can only help.
As far as asking you to check using 17070, was never a ‘fix’, it’s simple device to confirm the number at your home was the correct number , you eventually confirmed it was, so as a process of elimination, that was one possible issue dismissed as a possible cause of your issue, nowhere was it said that dialling a number would ‘fix’ your issue, if your car won’t start, someone asking has it got fuel in it, isn’t in itself going to make the car start, but it’s obviously a question that needs an answer
imjolly
Message 77 of 80
As I previously posted. If your neighbour is on BT and as you say has internet connection then if you use your BTID you should be able to connect to your neighbours BTWIFI/FON network and get an internet connection
pippincp
Message 78 of 80
Believe it or not there are many of us here who genuinely attempt to help.
Boss89
Message 79 of 80
I can't connect to FON and I need a LAN for my PC. I don't understand why this turned into the trial of the century but there you go. There's no resolution in sight and I'm no further forward
Boss89
Message 80 of 80
I've now had to take the embarassing task of apologising to my interviewer because my skype connection has dropped out on the 4G hub...
