Message 11 of 32
Re: No fibre
Indeed i have a dial tone no problem at all and can ring in and out on the landline just no broadband
Message 12 of 32
Re: No fibre
You said on your first post.
"I have rang my home number and it rings but my phone does not"
Is that still the case?
Which one of these is your master phone socket?
Single master sockets
Filtered sockets
Message 13 of 32
Re: No fibre
It does ring yes now so we have a valid phone line but no internet bt hub is plugged into the main socket as it was with my previous provider and it worked ok
Message 14 of 32
Re: No fibre
So the phone line has been provided, so I would expect that someone is going to the cabinet today, to route you through the fibre cabinet.
Were you on normal broadband or fibre broadband with your last provider?
Which one of those sockets that I indicated on those images, is your master socket?
Message 15 of 32
Re: No fibre
I was on fibre before but everythings been moved from talk talk to bt its plugged directly into the filtered socket which is the master socker no wiring had changed at my end
dnpark38
Message 16 of 32
Re: No fibre
Did you wait untill TT ceased working before you unplugged the TT Hub/router and then plug BT HUb in?
Message 17 of 32
Re: No fibre
Did BT say that you could get a fibre connection, as your existing one would have been disconnected?
What does it say on this checker against the VDSL row? Does it say available, or waiting list?
Broadband availability checker
Please remember to edit out your phone number before you post the results.
dnpark38
Message 18 of 32
Re: No fibre
You will guess I think from my question that he may well be still on TT for at least broadband.
Message 19 of 32
Re: No fibre
It says available as i say i had talk talk fibre until my contract ended on 15/12 i placed an order with bt that said it would be complete on 15/12 and i got a text yesterday at 18:30 to say my phone and fibre should now be life
Message 20 of 32
Re: No fibre
My fibre went off with talk talk yesterday as my contract expired so i assume bt take over the line and then provide a connection on it, however if the connection is not live or there are issues thenwhy send a text to say my services ate live
