Spectrum123
Message 1 of 11
No infinity 1 speed upgrade
Hello,
I've been on Infinity 1 since 2nd August 2017 and have not received the free speed upgrade that I've seen advertised was supposed to happen before November 2017. I never received the email and I assumed my speed wasn't fast enough, however I'm not so sure any more so wanted some advice as to whether my speeds look fast enough to qualify, before persuing things further. I did have a major fault with my line when it was set up causing a re-order to be applied, so that could also be the reason why I wasn't upgraded. Line stats are below, thanks in advance for any advice:
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084319+NQ71676790
Firmware version:
SG4B1000B522
Firmware updated:
16-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
4 Days, 3 Hours 3 Minutes 2 Seconds
Data rate:
10.00 Mbps / 55.00 Mbps
Maximum data rate:
19822 / 63643
Noise margin:
11.8 dB / 7.8 dB
Line attenuation:
18.3 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
10 REPLIES 10
Message 2 of 11
Re: No infinity 1 speed upgrade
from your stats you would benefit for free boost if you qualify   http://bt.custhelp.com/app/answers/detail/a_id/56165/~/questions-about-the-bt-infinity-1-speed-upgra...
Spectrum123
Message 3 of 11
Okay thanks, that's what I wanted to know. Is it something the support team on here can help with?
Message 4 of 11
the mods can check to see if you qualify  they will post here to help
Moderator
Moderator
Message 5 of 11
Hi @Spectrum123,
I'll be able to take a look at this for you. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Moderator
Moderator
Message 6 of 11
Hi @Spectrum123,
Thank you for sending in your details. I gave your home number a quick call, I'm sorry I didn't get speaking to you. I've placed an order to increase your Broadband speed. This is due to complete tomorrow and you should start to see and improvement over the next 48 hours. I'll check back with you on Friday to see how the connection is preforming.
PaddyB
Spectrum123
Message 7 of 11
@PaddyBThanks for your help. I can confirm that I've received an email with the order details.
Spectrum123
Message 8 of 11
@PaddyB I can confirm that the upgrade appears to have taken place. Download speed is basically the same but upload speed has doubled to 20Mbps. My stats are now:
Firmware updated:
16-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 20 Hours 57 Minutes 47 Seconds
Data rate:
20.00 Mbps / 55.05 Mbps
Maximum data rate:
20412 / 56869
Noise margin:
6 dB / 6.2 dB
Line attenuation:
18.5 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Moderator
Moderator
Message 9 of 11
Hi @Spectrum123 Thanks for the update. Paddy will be back in the office tomorrow and give you a call then.
cheers
John
Moderator
Moderator
Message 10 of 11
Hi @Spectrum123,
Thank you for posting back. I normally take a day or two for the speeds to increase. I've ran a few checks and the download speeds have increased. Your download profile is sitting at 61 Mbps, which is in line with what was estimated for your connection.
PaddyB
