PeteBoro64
Message 1 of 11
No internet
BTHomeHub5. Working fine for months. This morning devices see and connect to hub but report no internet connection. Tried reboots and factory reset. No joy. Tried my old BT home hub 4 - same problem. No reported broadband faults in area (I have BT Infinity). Any further suggestions ideas? Do I get an engineer out???
10 REPLIES 10
Message 2 of 11
Re: No internet
Are you connecting to the test socket with a new filter?
does your phone work ok?
PeteBoro64
Message 3 of 11
Re: No internet
Phone line is fine. I only have one socket - it has a phone socket and a broadband connection for the hub. No new filter or anything.
Message 4 of 11
Re: No internet
have you tried connecting to the test socket located behind the lower removable panel of the master socket
PeteBoro64
Message 5 of 11
Re: No internet
I connected my phone to the socket behind the panel and that works fine. Still no internet - all devices still "see" and connect to the hub.
PeteBoro64
Message 6 of 11
Re: No internet
Ps apparently I have a "type 5 SSFP infinity" socket.
mjnurney
Message 7 of 11
Re: No internet
a BT hub4 wont work with fibre , so only a 5 will work.
i have had the built in filter fail on the wall sockets before , so try your plugging the hub in to the master socket (unscrew the front panel and plug the hub directly in to the socket there)
try different filters too
other than that - youll need to call BT
Message 8 of 11
Re: No internet
the hh4 does work with fibre but you need to use a separate modem
OP already tried test socket with no imrovement
PeteBoro64
Message 9 of 11
Re: No internet
Hub seems mostly steady orange now but periodically flashes oranges and steady blue for short periods. I will call BT
PeteBoro64
Message 10 of 11
Re: No internet
Great ... BT can't provide an engineer until 31st Dec - kids with no internet all Xmas then (plus usual - it may cost you £129.99 warnings). Hub is now orange with orange broadband light flashing about every 20 seconds.
