NeilO
Moderator
Moderator
Message 11 of 23
Re: Broadband not working
Hi @Priya86in, welcome back to the community, I'm sorry to see you're broadband isn't working. I've moved your post over to your original thread to keep everything in the same place. What colour is the light on your Hub?
Priya86in
Message 12 of 23
It’s irange
Priya86in
Message 13 of 23
It’s orange
Priya86in
Message 14 of 23
It was working fine till afternoon. After that it went off
pippincp
Sage
Message 15 of 23
Do you have a dial tone on your phone?
Priya86in
Message 16 of 23
Priya86in
Message 17 of 23
Right now it’s flashing violet. Will it be done by tonight
NeilO
Moderator
Moderator
Message 18 of 23
@Priya86in, flashing purple means the hub is working ok but it's not connected to the internet. Can you check if the broadband cable (grey ends) is plugged in correctly? And if you're using a filter, check that's plugged in too.
Can you also confirm what socket you have? Keith has helpfully posted a diagram of these previously.
Priya86in
Message 19 of 23
I just checked and it’s back to orange now. Everything is connected
Priya86in
Message 20 of 23
When will this get sorted
