itani
Message 1 of 7
No more P2P limiting during peak times?
I've heard BT has now stopped limiting your connection during peak times. If this is true do I just re-order Unlimited BT Infinity 2? Anything else I need to know?
6 REPLIES 6
Sage
Sage
Message 2 of 7
Re: No more P2P limiting during peak times?
No nothing else you need to know. You can upgrade on-line.
It takes up to 5 days after the order is actived for the P2P throtrtle to be lifted.
You will also be in a new 12mth contract.
Guru
Message 3 of 7
Yes, you need to-recontract or ugrade providing you are on Infinity 1.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
itani
Message 4 of 7
I just made a new order and it says my order is now complete? I was on BT Infinity 2. I ordered this package
Have I done this correctly? I also have the 50GB Cloud
Guru
Message 5 of 7
Yea, you will have to wait 5 days for the P2P restrictions to be removed.
Twsited
Newbie
Message 6 of 7
im on infinity 2 and in still being throttled...... not a happy bunny!!
Message 7 of 7
@ Twsited
have you re contracted if so when
