Distinguished Guru
Distinguished Guru
Message 11 of 19
Re: Node and spine cable explanation needed please?
Hole in ground - fibre cable in - junction box - 1 fibre cable to cabinet, 1 fibre cable to next hole in ground = fibre node.
Distinguished Guru
Message 12 of 19
The spine cable connects the node to the cab
Cabnets get switched on any number at a time
If not, I'll try again 🙂
dfenceman
Expert
Message 13 of 19
Hi Jay152,
Try running http://www.superfast-openreach.co.uk/rural-broadband/ and see what result you get.
It is still in Beta testing and is not necessarily working to cabinet level for everybody.
Best regards,
dfenceman
Jay152
Message 14 of 19
Comes up with ?
Distinguished Guru
Message 15 of 19
Can you click on the "?" ?
dfenceman
Expert
Message 16 of 19
OK, so it did not work for you,
Best regards,
dfenceman
Jay152
Message 17 of 19
Like I said where does the spine cable come from?
Distinguished Guru
Message 18 of 19
The exchange
Jay152
Message 19 of 19
Ok thanks
