curtisb99
Message 1 of 14
Noise Margin Help
Why does my noise margin and line attenuation seem so high?
d168fd7e8e91f3a765945868d65938df
13 REPLIES 13
licquorice
Message 2 of 14
Re: Noise Margin Help
Your line attenuation isn't high and won't vary as it is a measure of your distance from the cabinet. Noise margin is high as you are on an Infinity 1 product capped at 10/55 and have plenty of headroom for higher speeds.
curtisb99
Message 3 of 14
How come I have been seeing peoples noise margin around 6? surely that affects things?
licquorice
Message 4 of 14
Your broadband speed is targeted to be the highest achievable with a 6dB margin. However, as your speed is already artificially capped at 10/55 due to being on an Infinity 1 product, the speed can go no higher thus your noise margin is higher. If you were on an Infinity 2 product (20/80) then your speed would increase to approx 61M and your noise margin reduce commensurately.
curtisb99
Message 5 of 14
If I switched to Infinity 2 what would the noise margin effect?
licquorice
Message 6 of 14
Why are you concerned about noise margin? Presumably you are concerned about speed, if so moving to Infinity2 would give you a slight increase to about 61M and give you a noise margin of 6dB  which you would probably not notice in the real world.
curtisb99
Message 7 of 14
I am trying concerned because when playing video games it doesn't feel right online and looking for anything that could be causing issues.
john46
Message 8 of 14
Your connection is fine just use it as normal
licquorice
Message 9 of 14
Whatever your problem is, it isn't 'noise margin'. Your connections stats look perfect.
ithomasseven
Message 10 of 14
what doesn't feel right? Are you seeing obvious lag?
