curtisb99
Message 11 of 14
BufferBloat Help
I am getting really bad bufferbloat which is affecting my online gaming.
pippincp
Sage
Message 12 of 14
Re: BufferBloat Help
What are you using to measure "bufferbloat"?
curtisb99
Message 13 of 14
dslreports and here are my results for bufferbloat....
1d55de291552ec52c3b687f18e750910
RogerB
Guru
Message 14 of 14
That'll tell you very little ... owing to the fact that you're asking a web-based commodity for an accurate connection attribute, when that same server you're asking is located over the Atlantic, on the Tucows network. And even though dslreports does have a UK name server (as well as others outside UK), there's little guarantee you went through it. At best any trans atlantic connection can add 100ms latency on a good day, and their servers are not busy. Try pinging some popular UK servers ...  15-40ms is your target, providing they answer the IGMP query.
