Hi all,
I recently had a lift and shift applied to my line by an engineer and got an extra 10Mbps to take me from 53Mbps to 63Mbps on my download. For some reason last night my noise margin figures have gone down to the following despite it being connected since the engineers visit and being stable above 6db. The last time I was with BT this happened, the engineer got my speed to 73Mbps that time, but then each 14 days it reduced by 2Mbps. I thought maybe weather related but it was fine throughout the snow period. I have a feeling it is going to drop each 14 days on the router reboot and take me back down to the infinity 1 type speeds.
Is this line error related or just more noise at the green box?
Maximum was 24/70 on the reconnect and it seems to come in a 2Mbps under the max hence the reason I think it will drop tonight
I'd be concerned if my noise margin was creeping UP, not down.
The normal target is 6dB but on a good line the downstream margin can be lowered to 3dB , in fact mine is sitting at 2.6dB right now. With a target of 3dB your downstream speed will increase by a few mbps, which is never a bad thing.
At present there is nothing wrong with your power levels and they could well drop further if G.Inp is enabled on your line.
your max attainable will fluctuate as the noise margin fluctuates - mine does - but never by much
Unfortunately it does indeed seem to be following the same pattern, I have lost 2Mbps of the 10 I got back from the lift and shift.
I have an original Openreach modem, would I be better using that to avoid the 14 day reset, would the original modem suppport G.inp?
Am I correct in thinking that my original Openreach ECI modem will not be compatible with G.inp when it rolls out on ECI cabinets. I have a tri band tp-link router that gives me better home coverage but it seems that G.inp will begin to roll out again soon on ECI cabinets and I’m assuming the old modem isn’t compatible.
It should be OK.
