Message 1 of 5
Nokia modem with serial number...
Could anyone know is it fully fibre or (copper & fibre)?  Which provider can have plans for budget friendly and high speed data .. we just bought this property. (Post Code AB25 2**)
[Mod edit: Amended postcode. Please don't post identifying information on the forum. Thanks]
4 REPLIES 4
Message 2 of 5
Re: Nokia modem with serial number...
As this is a forum for BT customers, I think you will have to Google other providers for the "Budget friendly" ones etc.  BT can be budget friendly but you have to watch them with the price increases.
In terms of what is available at the premises, try putting your phone number, (or address), in here:
If it says at the bottom that there is an ONT (Optical Network Terminal) already present then it will be full fibre via the Openreach network.  Any provider that uses the Openreach network will be able to provide full fibre.
Message 3 of 5
@lskishor That's a full fibre ONT
Message 4 of 5
I suspected it would be.
@lskishor Only the moderators and the community leaders can see your picture until it's released from quarantine.  I still can't see it.
Being naughty though, I did use the post code and full fibre is available in your street but not all the premises have it installed.  If you have a working ONT you should be ready to go.
Message 5 of 5
@lskishor
Blank out the serial number on the ONT picture. It is used to authenticate the connection.
