Robocop-99
Message 11 of 19
Re: Not Getting sync speeds paid for.
How can i post them here without saving as an image? Also I guess you want the information page vs the event log?
Robocop-99
Message 12 of 19
Think i worked it out. If this is what you was asking for 🙂2019-07-30 21_39_52-Information.jpg
Message 13 of 19
thanks and confirms stats in message 1 - essential package 40/10mb
Robocop-99
Message 14 of 19
So to summarise. I am paying for the Superfast Fibre Plus, which is speeds 80/20. However my router is syncing at 40/10 which is the essentials package so I am not getting what I have paid for.
So could someone please look into this for me.
Message 15 of 19
have you phone customer services or the options team on 0800800030 and see if they can help
Moderator
Moderator
Message 16 of 19
Hi @Robocop-99  sorry that you are not seeing the speeds you would expect from your broadband package. We will be happy to help get this fixed for you. I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
cheers
John
Moderator
Moderator
Message 17 of 19
Hi @Robocop-99  thanks for sending over your details. I checked and you are receiving speeds within your estimate but as it looks like the line the support I higher speed I have got the 40/10 profile changed to the 80/20. The order has completed now so can you check and see how your connection is performing and let me know.
cheers
John
Robocop-99
Message 18 of 19
Thank you so much for this! Was very worried i wouldnt be able to get it sorted! Modem is now syncing at.
and after a reboot of the router we're getting a solid 60mb+. Very very happy now. A+
Message 19 of 19
That's more like the correct speed and may yet get a bit better
