Message 1 of 11
Not clever enough to solve my own problem (high sync / lower throughput than expected)
Hello everyone. Below is how far I have gotten on my own, but now I need some help from clever people to reach the answer.
The issue
With the sync rate I am getting (80/20 without fail), it strikes me that I should be getting better throughput (speed test jumps to 67/17 immediately and stays there throughout)? Ping is typically 8-9 ms but often 5-6 ms depending on what you’re doing, time of day etc. The only outages we’ve ever had have been during heavy rain. Otherwise, pretty much faultless service for years.
My stuff
BT package: Superfast Fibre 2 Unlimited
Wholesale product: Maybe WBC FTTC 80/20?
Maximum throughput: 76 Mbps downstream / 19 Mbps upstream
Average throughput: 67Mbps downstream / 18Mbps upstream
Technology: Hybrid fibre / Fibre to the Cabinet (FTTC)
Transmission technology: Very High Speed Digital Subscriber Line 2 (VDSL2)
Exchange: GUILDFORD
Cabinet: 122 - Huwai - approx. 313 m away from property.
Dropwire looks like it’s not copper.
Filtered faceplate (these are fab by the way)
Huawei Echolife HG612 3B modem (but I briefly connected the BT Smart Hub to get the screenshot below)
40 cm CW1308 modem lead
Unifi Security Gateway router
...onwards into the home
Possible answer?
I couldn’t help but note that my IP Profile is almost exactly what this states: “21CN System - For ADSL2+ / WBC Products (Up to 24Mbps ADSL) With effect from late 2011, BT introduced a new Quantisation DLM system that results in much quicker updating of the IP profile. The calculation is based on your last sync speed minus an allowance for TCP & ATM overheads. The calculation should always be a fixed rate at 88.2% of your sync speed.
Other
If you could explain what the line stats mean, that would be good.
Thanks in advance for any guidance, more than happy to investigate further.
Screenshots
10 REPLIES 10
Message 2 of 11
Re: Not clever enough to solve my own problem (high sync / lower throughput than expected)
Run btspeedtester and when first test completes run diagnostic test and post result must be done with wired connection  http://www.speedtest.btwholesale.com/
Message 3 of 11
Hi. Ok this is what I got. I recall doing this a couple of weeks ago and it was higher, but either way while I'd say this is a bit low it's not dreadfully different than day-to-day performance.
Message 4 of 11
It looks like your profile is set to retransmission high at about 91% of connection speed and your download speed is ok for your profile. BT won't help at present as profile is ok and set bt DLM
Message 5 of 11
Ok, just so I understand this correctly (I don't): 1) Retransmission High is basically a setting where the system is saying 'this connection isn't good enough for X, so I'm going to try Y and see how it goes on that' - is that right? 2) Where you say it's set by DLM, how frequently is that DLM updated? Or can it ever be? Reason I ask is because when we moved in, *everything* was DIY-ed by a really bad DIY-er (I touched the living room light and got a shock, because the entire fitting was live). This included a total mess of telephone wires everywhere which, with a lot of Googling, I sorted - now the broadband is just plugged into the master socket and just sorting that wiring actually made a good difference on speed.
Sage
Message 6 of 11
DLM montors your line continuously. If, as you say, you have now resolved all the problems with the line then DLM will relent and reduce interleaving.
Message 7 of 11
Hub stats show Fast Path so OP's line isn't on interleaving.
Message 8 of 11
hub stats show fast all the time regardless of whether interleaving or fast - about time BT got this right
Message 9 of 11
Ok, well thanks for all the help. It's now slightly faster again (although I'm testing more consistently on ethernet) which is good. I get the feeling it's not going to get onto a higher IP Profile but will wait and see.
Message 10 of 11
TL;DR. Improving wiring provides a measurable benefit not only with increased speed, but also stability.
Just as an update to everyone that helped, I’m pleased to say in the weeks that followed the performance improved. I now consistently get 71/18 (testing on WiFi) and any speed test immediately jumps to that figure and stays there for the rest of the test (previously it would start a bit lower and creep up). I have to confess I don’t quite understand whether this is the correct maximum for my line or not but I’m definitely pleased with the results.
I am today having Halo 100 fitted (they told me they were installing FTTP but I think they are wrong) so will see how that goes.
Thanks again to those who helped.
