Message 1 of 13
Not getting minimum guarenteed speed anymore
Hi I’m not getting my contracts guarenteed minimum speed anymore, I had Openreach fit a new line from my master socket up to the pole due to a previous line issue and was achieving at least 50meg down speeds, when I renewed my contract I was told my guarenteed minimum was 42mbps download. Using the bt app to do a speed test shows the same as other speed test apps by saying at best I’m only getting 38 mbps download but the app says this is ok. Anything I can do??
12 REPLIES 12
Message 2 of 13
Re: Not getting minimum guarenteed speed anymore
Can you please repost the NEW connection information, as shown on your last theread https://community.bt.com/t5/BT-Fibre-broadband/Speed-increase/m-p/1821813#M262794
That will show whether your line speed has increased.
Message 3 of 13
How do I do that again I can’t remember sorry
Message 4 of 13
If you are using the BT Smart hub you can get your connection stats by, Opening a new web browser on your connected device and type 192.168.1.254 or bthomehub.home into the address bar. This will open the Hub Manager.  Click Advanced Settings’ and then ‘Technical log’
Message 5 of 13
Thanks see below: Product name: BT Hub 6A
Serial number: +084319+NQ70168872
Firmware version: SG4B1000B540
Firmware updated: 15-May-2018
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 0 Days, 18 Hours 18 Minutes 48 Seconds
Data rate: 16.86 Mbps / 40.61 Mbps
Maximum data rate: 17067 / 48445
Noise margin:6.2 dB / 6.3 dB
Line attenuation: 18.3 dB
Signal attenuation:
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Data sent / received: 8329 MB Uploaded / 204936 MB Downloaded
Broadband username: bthomehub@btbroadband.com
BT Wi-fi: Active
2.4 GHz wireless network name: BTHub6-8M2H
2.4 GHz wireless channel: Smart (Channel 11)
5 GHz wireless network name: BTHub6-8M2H
5 GHz wireless channel: Smart (Channel 36)
Wireless security: WPA2 (Recommended)
Wireless mode: Mode 1
Firewall: On
MAC address: 24:7F:20:A7:45:F9
Software variant: -
Boot loader: 7.33.1
Message 6 of 13
From what I have noticed since the last time I posted here my maximum data rate has increased but my actual speed has gone down. Any ideas before I call BT. I used to get 50mbps when new line was installed now it just goes down to 38-40 at best
Sage
Message 7 of 13
As has been reported many times on this forum this has happened on renewal due to the loss of G.INP.
This should automatically kick in again in 10-14 days and return your speed. It cannot be done manually.
Message 8 of 13
It has been over 3 months....so I don’t think that’s correct
Sage
Message 9 of 13
Sorry but I'm not a mind reader, had I known it was 3 months ago...
Message 10 of 13
Sorry forgive my reply for sounding rude, I was writing it while out and about.
