pookie
Message 11 of 22
Re: Not getting the upload speed quoted
Thank you. Is a factory reset when you leave the hh powered on and hold a pin in the hole for 15 seconds until lights flash or should hh be in standby? I ask as my download was mid 30mb but for last few weeks hasn't got above 20mb
Message 12 of 22
yes that is a factory reset when you hold a pin in
pookie
Message 13 of 22
Thank you
ryansjk
Message 14 of 22
If the engineer checked the line and told me I'd get the max download and upload surely that means the connection to the cabinet is fine. I've tried factory reseting 20+ times and nothings changed. I don't think 6.5 is a close estimate to 13.5 at all. That's worse than half, 'estimate' or not.
pookie
Message 15 of 22
Do I need to use the BT provided red cable to connect hh3 to modem? As it was so long I use a shorter cat 5e cable. Could that have caused my speed drop?
Message 16 of 22
Unless the lead is faulty it should have no effect
Message 17 of 22
The shorter cable would not make a difference unless it is faulty. You could always swap them back just to be sure.
Message 18 of 22
@ ryansjk
Are you doing the speedtest with a wired(Ethernet ) connection or a wireless one
ryansjk
Message 19 of 22
@john46 wired, with two pc's. Test was also tried on a Samsung S3 on wireless, same problem.
Message 20 of 22
Have you tried with any anti virus. You have turned off as some av's have given strange results
