tom1990
Message 1 of 24
On BT Infinity 2 package and getting 51mb?
Hi, I've had BT Infinity 2 for years now and been getting around 50mb. Always wondered if I should be getting more,  can someone have a look at my speed test details and see if every looks right. Thanks alot.bt speed 1.pngbt speed 2.pngbt speed 3.png
Message 2 of 24
Re: On BT Infinity 2 package and getting 51mb?
can you post stats from your router
at present from the profile shown you have a conenction speed right at bottom of the estimated speed range 74/52mb
tom1990
Message 3 of 24
Message 4 of 24
thanks
are you having problems with conenction dropping just the tplink does not shown internet connection time
which exchange and cab as you deleted that from dslchecker
tom1990
Message 5 of 24
No my connection is stable, just I've always thought I may be getting less speed than I should be.
I didnt delete nothing ? Shall I run the dsl checker again?
tom1990
Message 6 of 24
orry, see what I did now. Here you go....
Message 7 of 24
Unfortunately like me you are on and ECI cab and at present there is no G.INP which would boost your conenction
tom1990
Message 8 of 24
Thanks for the feedback.
Any idea when that will change, if ever? ...Also if I'm  stuck with 50mb, is it worth me being on BT Invinity 2?
Do you think asking them to reset the line may help?
Message 9 of 24
Looks like DLM has banded your line at55M
tom1990
Message 10 of 24
Hi, thanks for the help. Can you explain what that means please and what best think for me to do? Thanks alot.
