Moderator
Moderator
Message 11 of 24
Re: On BT Infinity 2 package and getting 51mb?
Hi @tom1990 sorry you are not achieving the speeds you would expect.
As your profile looks like it may be banded please send us over your details and we will see what we can do to help remove the banding. You can contact us by clicking on my user name and selecting contact the mods.
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Message 12 of 24
This link may help. https://community.plus.net/t5/Library/FTTC-DLM-What-it-is-How-it-works/ba-p/1322799
Just try and maintain a stable connection
Moderator
Moderator
Message 13 of 24
Hi @tom1990 I called earlier sorry I could not reach you. I just wanted to know that a reset for your profile has been requested. Please can you check you connection on Monday evening and post back to let me know if anything has changed.
Cheers
John
Kudos”
tom1990
Message 14 of 24
Sorry I wasn't there. Thank you for doing a reset, I'll reply back then on Monday night. Thanks.
tom1990
Message 15 of 24
Hi, I've tested the line a few times tonight and it's changed but still getting same speed. Here are some results ....
Moderator
Moderator
Message 16 of 24
Hi @tom1990 Thanks for checking that for me. I'll check that the order has completed tomorrow and update you then.
Cheers
John
Kudos”
tom1990
Message 17 of 24
Distinguished Guru
Distinguished Guru
Message 18 of 24
Looks like the reset has gone through but there may be a delay for G.INP to be activated. This will be totally automatic and cannot be done manually. I'd give it till the end of the week at least.
tom1990
Message 19 of 24
Ok then, thanks. Hopefully all goes well.
tom1990
Message 20 of 24
Hi, My speed is still stuck at 50 mb. Did the order go though ?
