Moderator
Moderator
Message 21 of 24
Re: On BT Infinity 2 package and getting 51mb?
Hi @tom1990 I've checked and the order has completed and the profile is not banded now.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Message 22 of 24
from what you posted previously you are on an ECI cab so there will be no G.INP boost at present
tom1990
Message 23 of 24
Ok then, still only getting 50mb. My current package is about to expire, so it looks like I'm better off going down to infinity 1 instead of 2, that's if I stay with BT. Virgin say can offer me packages up to 350mb. How come I can only hit 50mb with you BT?
Message 24 of 24
your last stats showed connection speed of 57mb which just at bottom of estimated range  the figures quoted by BT are conenction speed not download speed
Virgin is different connection and does not use openreach
