Moderator
Moderator
Message 11 of 15
Re: Ongoing fault!
Thanks for letting me know @philc2.
I will follow up with you again tomorrow once the drop wire has been changed.
Matt
Moderator
Moderator
Message 12 of 15
Re: Ongoing fault!
@philc2 thanks for taking my call this afternoon.
It's amazing the issues an old joint in cabling can cause however I'm really glad to hear that the fault is now fixed.
Matt
philc2
Message 13 of 15
Re: Ongoing fault!
Everythings ok now, thanks for the help!
philc2
Message 14 of 15
Re: Ongoing fault!
Thanks again Matt, my speed today 43 and 8 which is pretty good. 🙂
Phil
pompey1898
Expert
Message 15 of 15
Re: Ongoing fault!
Another success for the Mods !!
