gbukgbuk
Message 1 of 6
Ongoing speed variances...very frustrating
BT Infinity 2, Home Hub 5. Powerline adapters.
For ages I got 35mbps down and 5mbps up. Two months ago HH reset and then got 27 down and .475 mbps up. S/N read 14.00/6.00. Was always approx 6 and 6. Every so often HH resets and often up speed goes back up tp approx 5mbps but down stays approx 27mbps. This has been happening for weeks. Sometimes I think I can hear noise on the line. Now plugged into test socket in master socket to get best possible result, but still it goes up and down as before. Have contacted BT but they can't/ won't help. Have kept a record of HH stats. below is a sample, but is representative of many I have kept.
Very frustrating. I want to get it fixed. Is the problem with BT? I have no extentions and am now plugged into test socket in master socket with filter.
What can I do? Any help very appreciated.
John
1. Product name:
BT Home Hub
2. Serial number:
+068343+NQ40921385
3. Firmware version:
Software version 4.7.5.1.83.8.204 (Type A) Last updated 11/01/15
4. Board version:
BT Hub 5A
5. DSL uptime:
0 days, 17:19:24
6. Data rate:
1804 / 27528
7. Maximum data rate:
4835 / 36165
8. Noise margin:
15.3 / 6.0
9. Line attenuation:
24.8 / 26.3
10. Signal attenuation:
24.8 / 23.7
11. Data sent/received:
1.9 GB / 24.2 GB
12. Broadband username:
bthomehub@btbroadband.com
13. BT Wi-fi:
14. 2.4 GHz Wireless network/SSID:
BTHub5-X5QZ
15. 2.4 GHz Wireless connections:
Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:
WPA2
17. 2.4 GHz Wireless channel:
Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:
BTHub5-X5QZ
19. 5 GHz Wireless connections:
Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:
WPA2
21. 5 GHz Wireless channel:
22. Firewall:
Default
23. MAC Address:
34:8a:ae:b5:a6:42
24. Modulation:
G.993.2 Annex B
25. Software variant:
AA
26. Boot loader:
1.0.0
23/07/2015 @ 08.41
1. Product name:
BT Home Hub
2. Serial number:
+068343+NQ40921385
4. Board version:
BT Hub 5A
5. DSL uptime:
0 days, 02:39:23
6. Data rate:
5212 / 29819
5213 / 37535
8. Noise margin:
6.0 / 6.1
24.7 / 26.1
24.7 / 23.5
2.0 GB / 24.9 GB
13. BT Wi-fi:
BTHub5-X5QZ
WPA2
BTHub5-X5QZ
WPA2
22. Firewall:
Default
23. MAC Address:
34:8a:ae:b5:a6:42
24. Modulation:
G.993.2 Annex B
AA
26. Boot loader:
1.0.0
5 REPLIES 5
Sage
Sage
Message 2 of 6
Re: Ongoing speed variances...very frustrating
If you try a quiet line test with a corded phone  (17070 option 2) and hear any noise then you need to report a line fault, do not mention broadband.
Once the line fault is sorted out then your BB should return to normal.
Message 3 of 6
your connection time is only 17hrs was that a manual reset or router dropping conenction?  was this self install or engineer?
can you enter your phone number and post results  remember to delete your number
https://www.btwholesale.com/includes/adsl/main.html
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
gbukgbuk
Message 4 of 6
Trying hard to copy data from wholesale line test but can't suss it!
John
gbukgbuk
Message 5 of 6
Router dropped comnnection. Engineer install.
Best I could manage of copying data from BT Wholsale test.....
BT BROADBAND AVAILABILITY CHECKER
Telephone Number  on Exchange WYMONDHAM is served by Cabinet 14
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High
Low
High
Low
FTTC Range A (Clean)
28
19.7
5.7
3.7
Available
FTTC Range B (Impacted)
22.2
10.5
5
1.8
Available
WBC ADSL 2+
Up to 1
1 to 3.5
Available
ADSL Max
Up to 1
0.75 to 2.5
Available
WBC Fixed Rate
0.5
Available
Fixed Rate
0.5
Available
Other Offerings
Fibre Multicast
Available
Copper Multicast
Available
BET
Up to 2
Available
Hope you can decipher these stats.
Many thanks,
John
Sage
Sage
Message 6 of 6
Your "Clean" range from the checker is a download of 19.7 - 28Mbps so even though your HH5 reports you line can support more I doubt if BT will do anything about it.
As you think you can sometimes hear noise on the line this would affect you Broadband which is why I suggested trying a quiet line test.
If there is noise you MUST get the line fault repaired before anything else.
