JibJab
Message 1 of 40
Only BT Wholesale speed test says 75meg
Hi,
10 days after having my infinity installed I did a speed check. It consistanly shows 20 meg download and I'm estimated to get 70. I rang BT and they asked me to check my speed on the BTWholesale site, her my speed consistantly shows as 75meg. I tried several other speed check sites and they all show 20meg download. I asked why and the guy said they must not be able to show higher so i tried the same sites on a different line, they could all show up to at least 120meg.
I starting to feel like the Bt speed check is completely wrong. If only one other site was showing differently I could see it would be that site but ALL other checks are showing 20 or below. I've rang BT a few times and all they say is there is no problem and the line check shows 75meg and that all the other sites must not be fibre compatable, which ive checked on another line and they are accurate for higher speeds on those lines.
I'm using a wired connection. Any help would be greatly appreciated as I dont know where to go from here.
Jib
39 REPLIES 39
Distinguished Expert
Message 2 of 40
Re: Only BT Wholesale speed test says 75meg
Have you tried this one? http://www.thinkbroadband.com/speedtest.html
To say thanks for a helpful answer, please click the white star
JibJab
Message 3 of 40
that is showing similar to the others 19.16
Message 4 of 40
Can you post the graph displayed?
JibJab
Message 5 of 40
Message 6 of 40
Yeah, that shows it's pretty much bang on 20Mbps. I could understand it if it was wireless but not wired.
Can you get hold of your IP Profile by running the speedtest at www.speedtest.btwholesale.com and doing the further diagnostics? maybe that is set to 75Mbps?
JibJab
Message 7 of 40
I just tried the BT wholesale test again and it shows 76.66, i clicked further diagnostics but because on their site its showing the speed it should be it just says We were unable to identify any performance problem with your service at this time. I just dont get why every other site shows 20 ish, I feel like the BT one is showing it wrong.
Message 8 of 40
It should have shown you a graphic with a couple of green bars for your download and upload
JibJab
Message 9 of 40
yes sorry it did
Download speedachieved during the test was - 76.5 Mbps
 For your connection, the acceptable range of speedsis 16 Mbps-77.43 Mbps .
 Additional Information:
 IP Profile for your line is - 77.43 Mbps
Upload speed achieved during the test was - 15.41Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance
Distinguished Guru
Distinguished Guru
Message 10 of 40
Try turning off your antivirus during testing on any other speedtest sites.
