pietruzzo
Newbie
Message 1 of 13
OpenWrt HomeHub 5a BT Infinity PPPoE hangup?
Hello everyone, I am a fairly new BT customer.
As I need to use my own appliances for study and research reasons, I have been trying to setup my BT HomeHub 5a with OpenWrt SNAPSHOT, r6486-e273860351.
Basically the issue I am facing is, as the modem establish a connection with the cabinet, it suddenly receives a terminate imput and therefore it hangup on the connection. I do believe OpenWrt here has nothing to do with it, but at the same time I want to rule out the modem settings as well.
Configuration:
config dsl 'dsl'
        option annex 'b'
        option xfer_mode 'ptm'
        option line_mode 'vdsl'
        option ds_snr_offset '0'
        option tone 'a'
config interface 'wan'
        option proto 'pppoe'
        option delegate '0'
        option ifname 'dsl0.101'
        option username 'bthomehub@btinternet.com'
        option password 'bt'
config device 'wan_dev'
        option name 'dsl0'
        option macaddr '34:8a:ae:96:e5:eb'
WAN status upon connection attempt(see HANGUP as error code)
root@OpenWrt:~# ifstatus wan
        "up": false,
        "pending": true,
        "available": true,
        "autostart": true,
        "dynamic": false,
        "proto": "pppoe",
        "device": "dsl0.101",
        "data": {
        "errors": [
                        "subsystem": "pppoe",
                        "code": "HANGUP"
root@OpenWrt:~#
Here is the interesting part, where we can actually see the whole dialing process taking place:
1) PPPoE authentication has been established:
(Connected to a4:7b:2c:2d:17:63 via interface dsl0.101; peer from calling number A4:7B:2C:2D:17:63 authorized);
2) Local  IP address is 109.156.246.196;
3) Remote IP address(CGN ) is 172.16.18.175;
4) Primary  DNS address is 81.139.56.100;
5) Secondary DNS address is 81.139.57.100;
6) Connection is terminated (LCP terminated by peer; Connect time 0.0 minutes; Modem hangup; Connection terminated).
Sun Mar 18 03:25:37 2018 daemon.notice netifd: Interface 'wan' is now down
Sun Mar 18 03:25:37 2018 daemon.notice netifd: Interface 'wan' is disabled
Sun Mar 18 03:25:37 2018 daemon.notice netifd: Interface 'wan' is enabled
Sun Mar 18 03:25:37 2018 daemon.notice netifd: Interface 'wan' is setting up now
Sun Mar 18 03:25:37 2018 daemon.err insmod: module is already loaded - slhc
Sun Mar 18 03:25:37 2018 daemon.err insmod: module is already loaded - ppp_generic
Sun Mar 18 03:25:37 2018 daemon.err insmod: module is already loaded - pppox
Sun Mar 18 03:25:37 2018 daemon.err insmod: module is already loaded - pppoe
Sun Mar 18 03:25:38 2018 daemon.info pppd[17577]: Plugin rp-pppoe.so loaded.
Sun Mar 18 03:25:38 2018 daemon.info pppd[17577]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7
Sun Mar 18 03:25:38 2018 daemon.notice pppd[17577]: pppd 2.4.7 started by root, uid 0
Sun Mar 18 03:25:38 2018 daemon.info pppd[17577]: PPP session is 6305
Sun Mar 18 03:25:38 2018 daemon.warn pppd[17577]: Connected to a4:7b:2c:2d:17:63 via interface dsl0.101
Sun Mar 18 03:25:38 2018 kern.info kernel: [  211.991695] pppoe-wan: renamed from ppp0
Sun Mar 18 03:25:38 2018 daemon.info pppd[17577]: Using interface pppoe-wan
Sun Mar 18 03:25:38 2018 daemon.notice pppd[17577]: Connect: pppoe-wan <--> dsl0.101
Sun Mar 18 03:25:38 2018 daemon.info pppd[17577]: CHAP authentication succeeded: CHAP authentication success
Sun Mar 18 03:25:38 2018 daemon.notice pppd[17577]: CHAP authentication succeeded
Sun Mar 18 03:25:38 2018 daemon.notice pppd[17577]: peer from calling number A4:7B:2C:2D:17:63 authorized
Sun Mar 18 03:25:38 2018 daemon.notice pppd[17577]: local  IP address 109.156.246.196
Sun Mar 18 03:25:38 2018 daemon.notice pppd[17577]: remote IP address 172.16.18.175
Sun Mar 18 03:25:38 2018 daemon.notice pppd[17577]: primary   DNS address 81.139.56.100
Sun Mar 18 03:25:38 2018 daemon.notice pppd[17577]: secondary DNS address 81.139.57.100
Sun Mar 18 03:25:38 2018 daemon.info pppd[17577]: LCP terminated by peer
Sun Mar 18 03:25:38 2018 daemon.info pppd[17577]: Connect time 0.0 minutes.
Sun Mar 18 03:25:38 2018 daemon.info pppd[17577]: Sent 0 bytes, received 0 bytes.
Sun Mar 18 03:25:38 2018 daemon.notice pppd[17577]: Modem hangup
Sun Mar 18 03:25:38 2018 daemon.notice pppd[17577]: Connection terminated.
Sun Mar 18 03:25:38 2018 daemon.info pppd[17577]: Sent PADT
root@OpenWrt:~#
Lastly I tried quite few DSL modem firmwares for the lantinQ chipset,  see here https://xdarklight.github.io/lantiq-xdsl-firmware-info . Ultimately I ended up sticking with Firmware Version:  5.9.0.12.1.7 as it appears to be one of the latest ones and has Vectoring instructions enabled. Either way, it really made no difference regardless of the versions.
root@OpenWrt:~# /etc/init.d/dsl_control status
ATU-C Vendor ID:                          Infineon 178.6
ATU-C System Vendor ID:                   45,43,49,20,74,65,6C,65
Chipset:                                  Lantiq-VRX200
API Version:                              4.17.18.6
XTSE Capabilities:                        0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x2
Annex:                                    B
Line Mode:                                G.993.2 (VDSL2)
Profile:                                  17a
Line State:                               UP [0x801: showtime_tc_sync]
Forward Error Correction Seconds (FECS):  Near: 0 / Far: 10250
Errored seconds (ES):                     Near: 0 / Far: 83
Severely Errored Seconds (SES):           Near: 0 / Far: 0
Loss of Signal Seconds (LOSS):            Near: 0 / Far: 429
Unavailable Seconds (UAS):                Near: 36 / Far: 36
Header Error Code Errors (HEC):           Near: 0 / Far: 0
Non Pre-emtive CRC errors (CRC_P):        Near: 0 / Far: 0
Pre-emtive CRC errors (CRCP_P):           Near: 0 / Far: 0
Power Management Mode:                    L0 - Synchronized
Latency [Interleave Delay]:               0.0 ms [Fast]   0.0 ms [Fast]
Data Rate:                                Down: 54.995 Mb/s / Up: 9.995 Mb/s
Line Attenuation (LATN):                  Down: 8.6 dB / Up: 6.3 dB
Signal Attenuation (SATN):                Down: 8.6 dB / Up: 6.2 dB
Noise Margin (SNR):                       Down: 16.7 dB / Up: 19.7 dB
Aggregate Transmit Power (ACTATP):        Down: -4.7 dB / Up: -4.6 dB
Max. Attainable Data Rate (ATTNDR):       Down: 93.126 Mb/s / Up: 29.996 Mb/s
Line Uptime Seconds:                      250
Line Uptime:                              4m 10s
root@OpenWrt:~#
Please help me understanding wheter or not I am doing anything wrong configuration wise. I called BT customer support and when explaining my issue a super rude lady told me BT does not support third party modems and that they are delivering the service promised and that if I am not happy I can go ahead and cancel the contract and that I will be charged for it.
It really doesn't work like that does it? I am in CSR myself and I would never speak like that to any of my customers.
EDIT: Find attached web configuration screenshot:
12 REPLIES 12
Message 2 of 13
Re: OpenWrt HomeHub 5a BT Infinity PPPoE hangup?
You are wasting your time with customer support as they are not technical. Obviously BT cannot and  do not support third party devices as there are an infinite number to have knowledge of. However, the operator could have been a bit more civil.
Everything looks to be setting up correctly and authenticating so not sure why the connection is unhappy and forces release.
You will probably get much better information from Open Wrt forums or Kitz forum.
Message 3 of 13
Username is bthomehub@btbroadband.com
bt will not help if you are changing the firmware
Message 4 of 13
Well spotted, I read what I wanted to see rather than what I saw. Seems odd that it is authenticating ok with wrong username though.
pietruzzo
Newbie
Message 5 of 13
It actually wont authenticate using  bthomehub@btbroadband.com.
Also to clarify the scenario, the HomeHub 5a is a router I purchased off of Ebay and I am not requesting help for it in specific.
I actually just tried using a Draytek Vigor 130 a friend of mine just brought and got the same result. There is no fw alteration here, and if CSR is not technical than please let me speak with somebody who is and understands, regardless of the modem model / version. I cannot run my labs using the HomeHub6, especially because of the CGN.
Message 6 of 13
There is nobody technical you can speak to.
pietruzzo
Newbie
Message 7 of 13
You mean here on the forum or in general? I mean how and where can I get technical support from BT and for my issue?
Message 8 of 13
As already said BT will not help with the changes you want to perform. The hub they provide works perfectly well with bt broadband and the do not support any 3rd party routers or software/firmware
Message 9 of 13
In general. Any technical support is a paid for option and will be limited to vanilla BT devices.
Your first step is to ensure your broadband works ok with a standard BT hub. If it doesn't, then a fault can be investigated, if it does then you are on your own I'm afraid.
pietruzzo
Newbie
Message 10 of 13
What can I say... I am afraid I am better off cancelling it. Sure enough I will leave a "good" feedback on TrustPilot.
