chrisgwynne
Message 1 of 11
Openreach Modem setup
I have bt home hub 6 but want to switch to Ubiquiti router.
I have an openreach modem that I'm trying to set up. I factory reset it then changed the software so I can access the admin side. It connects to the internet on the modem side, I.e. see up and downstream see that it's set IP address and under diagnostics I can ping IPs.
It's set up in PPPOE mode with username bthomehub@btbroadband.com
However connecting it to my desktop computer it wont connect to the internet at all whatsoever no matter what I do. Similarly if I connect it to Ubiquiti USG it wont connect over PPPOE.
My ipv4 settings on my NIC are 192.168.1.100 / 255.255.255.0 / 192.168.1.0 respectively. Have I missed a step anywhere? Whether it be in openreach modem or configuring the NIC Crd wrongly?!
Spent a good few days pulling my hair out over this 😣
Tags (3)
10 REPLIES 10
chrisgwynne
Message 2 of 11
Re: Openreach Modem setup
When my NIC card is set to obtain details from network and I plug in my HH6 router into my desktop pc I get instant connection to internet. So there's no overall issue with the card.
gg30340
Message 3 of 11
The Openreach modem does not need set up. It should be just plug and play. If you have hacked it to access the admin side I would suggest that initially you factory reset it then try and make the connection. This will allow you to ascertain that the modem is working.
If you want to have a connection directly to your PC without a router follow these steps.
To make a direct connection from your PC to the modem which will eliminate the router.
Step 1: Remove the homehub/router  from the modem
Step2: Connect your pc/laptop into the modem using LAN1 port
Step3: Open network and sharing centre on windows and click set up a new connection or network
Step4: Connect to the internet then click make a new connection Broadband PPPoE
Step5: Username bthomehub@btbroadband.com and the password as BT
Step6: connect, If it doesn't,keep pressing try again until it does.
chrisgwynne
Message 4 of 11
Thanks for the reply.
I have just reset my modem, unplugged power, reset, etc etc. Replugging power (green light), plugging into lan1 or lan2 (green light), plug into DSL (no green light). I waited a good 5 minutes, twice, to see if it was me. But modem will not light up for DSL. Yet it did with the hacked version.
gg30340
Message 5 of 11
Did you buy this modem or did you have it fitted previously and know for a fact that it works?
See link for how to plug modem in.
https://btsupport.custhelp.com/ci/fattach/get/2914527/1362479020/redirect/1/filename/BT%20Infinity%2...
Lan 2 does not work. It must be plugged into Lan1
chrisgwynne
Message 6 of 11
I bought it off eBay. With a hacked version DSL does work and I can ping out from the modems admin page. It will just not connect to the internet when a computer is plugged to it. Literally going to throw it in the bin shortly.
Not sure what else to do. I have bought a brand new hub 3 which will arrive this week I can put this into bridge mode and it does the same thing, I have read? Ultimately I just want my Ubquiti USG up and running.
gg30340
Message 7 of 11
I take it you are a BT Fibre Broadband customer?
When you say it will not connect when a computer is plugged into it, I take you are making a direct connection and not using a router?
The HH3 is an ADSLmodem/router, it will not work with fibre without a VDSL modem.
chrisgwynne
Message 8 of 11
Yes BT Fibre.
Currently making a direct connection openreach modem to computer. However once I reset it, no DSL came.
gg30340
Message 9 of 11
Presumably your HH6 still lets you connect to the Internet. ie there is no line fault.
I can only suggest that you to do a further reset of the modem by pressing and holding down the reset button on the back of the modem for at least five seconds then releasing the button and waiting a few minutes for the power light to switch on.
If the DSL light is still off, disconnect the power cable, wait a few minutes then reconnect the power cable and wait. It might take more than the five minutes  you have been waiting for the modem to connect so leave it a bit longer to see if it will eventually connect.
If that doesn't work there are other forum members with more experience of the Openreach modem than I have and they may be able to offer some other advice.
pippincp
Sage
Message 10 of 11
As you have said @gg30340 the Openreach modem is plug & play and the HH3 is a dumb router and cannot connect to VDSL without a modem.
