licquorice
Message 21 of 27
Re: Openreach ONT installed under the stairs - odd place?
You can only edit a post for one hour after posting.
pippincp
Sage
Message 22 of 27
@licquorice  I must resist the urge to speedread.🤣
licquorice
Message 23 of 27
@pippincp  😀😀😀
yorkspark
Message 24 of 27
Whats behind the 4 mod 2 gang plate with the black inserts?
Devon_Dave
Distinguished Guru
Message 25 of 27
  • Are you sure that there are no ethernet sockets around the house, maybe near to where you tv would go?  It does look there maybe sockets below the ONT
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
pippincp
Sage
Message 26 of 27
@yorkspark  That is just for incoming connections, the black inserts are draft excluders similar to those for letterboxes.
@Devon_Dave  Is the above what you are thinking may be Ethernet connections?
Jake883
Message 27 of 27
If it is anything like my new build the socket is for a telephone line that is linked to behind the TV
No ethernet though
