Sage
Message 11 of 21
Re: Openreach or BT records wrong?
Then get back onto Openreach and demand they update their records. BT Wholesale use the Openreach database for their DSL checker.
Why can't you upload an image.
Message 12 of 21
No idea, I choose a file and it doesn’t attempt to upload, just says no file selected after I choose a file.
Sage
Message 13 of 21
You should just click on the camera icon and select the file.
Message 14 of 21
Must be an issue with mobile, I can select an image by “choose file”, but I select one and nothing uploads, doesn’t matter either way, thank you for the help, I’ll try to contact openreach and get my records updated.
Message 15 of 21
So, a quick update, I've managed to get Openreach to update their records, they were checking 3 different systems and one of them was showing my line was exchange only, they sent an engineer out because they needed to check how the routing in the cabinet coincided with their existing records to update it properly, got a phone call this morning from Openreach saying everything is showing Fibre to the Cab now, Thanks for all the help people.
Sage
Message 16 of 21
Thanks for letting us know. Glad you got it sorted.
Message 17 of 21
Dear MrNeeds,
I hope you’re well. Sorry for digging out this old thread. I have a question: how did you manage to get Openreach to update their records? I’m in the same situation, where I can’t activate a FTTP line because I don’t show up on their records, whilst having their modem installed and with only green lights.
Any suggestion?
thank you so much!!
Sage
Message 18 of 21
Contact the FTTP team 0800 587 4787. Have the serial number of the ONT to hand as they will need it to register the ONT.
Message 19 of 21
Thank you! I’ve been doing this for the last 10 days, sadly, I’ve given them (and the Openreach engineers) all the serial numbers I have. Seems weird that it’s taking them so long just to ‘tick a box’...any advice?
thank you so much for your help
Sage
Message 20 of 21
