supertedster
Message 11 of 25
Re: Orange light on new smart hub 2
"Yes the hub has the red WAN port, which I've tried in the 4 ports on the modem."
I was asking about this and wondering about the 4 port modem?
Cheers
Ted
pippincp
Message 12 of 25
@supertedsterFurther evidence of making clear what you are asking about. However, there is no 4 port ONT in use by Openreach, there was a 2 port one but the second port was for Fibre voice which has been discontinued. Present ONTs have only one port.
As to the rest without an answer from the OP we  can only assume that the hub has a red  ethernet port and the OP was referring to the ethernet cable supplied with the red ends, not that either the ONT or hub knows or cares what colour the ends of the cables are.
sjm1
Message 13 of 25
Sorry, I assumed the white box in the wall was an ONT.  Here's some photos of the setup. Solid green lights on power, optical and Lan1bt01.jpgbt02.jpgbt03.jpg
Keith_Beddoe
Message 14 of 25
@sjm1
When did BT tell you your service was activated, as you cannot assume an existing connection will work?
What service did you order from BT Retail?
You have an FTTP connection which has probably not yet been configured, but you have everything connected up correctly.
pippincp
Message 15 of 25
Looks like I was wrong, haven't seen one of those ONTs before.
sjm1
Message 16 of 25
I ordered Full Fibre 100, was sent an email it was ready to use 26th July. Anyone from BT here that can check this?
Keith_Beddoe
Message 17 of 25
This is just a customer to customer forum, you would need to contact BT.
imjolly
Message 18 of 25
Phone FTTP TEAM and see if they can help you 08005874787
licquorice
Message 19 of 25
Not seen an ONT like that before but I suspect the 'Internet' LED would be lit if the service was activated.
Perhaps @Starwire might be along to enlighten us, if you'll forgive the pun.
Starwire
Recognised Expert
Message 20 of 25
That’s an ECI ONT. Very rare.
I believe Openreach only used ECI in the original FTTP Trial Areas before switching to Huawei and then subsequently Nokia.
Personally I wouldn’t want to be on ECI, it’s antiquated and the speeds are limited. Last I heard they were supposed to be removing ECI Head Ends in favour of Nokia.
