Starwire
Recognised Expert
Message 21 of 25
Re: Orange light on new smart hub 2
I’ll be honest I don’t know if that ‘Internet’ light should be on or off?
Its an ECI ONT and I have zero experience with them. I’ve only ever seen one in a classroom and it wasn’t connected to a live PON.
As I said above in my reply to Pippin ECI wasn’t used for very long before they switched to Huawei and Nokia, which are the only two I’ve worked on.
sjm1
Message 22 of 25
Thanks all for your help, and thanks @Starwire for the heads up regarding ECI modems.
Will get in touch with the FTTP TEAM tomorrow to see what gives.
DavidM
Moderator
Moderator
Message 23 of 25
Hi @sjm1 and thanks for posting.
I'd bee vey interested to know how this is resolved so please post back and let us know how you get on.
Cheers
David
sjm1
Message 24 of 25
I was told by the engineer that it was a software problem at the exchange, he made a call and they got it working.
JohnC2
Moderator
Moderator
Message 25 of 25
Hi @sjm1, thanks for posting back and great news that the engineer got you up and running.
cheers
John
