iSean
Message 1 of 4
Order details......
I don't want to call BT just yet as it may be an error but just done BT Infinity 2 and it says 40/10...
Has anyone else noticed? Is it just a website error? Smiley Frustrated
3 REPLIES 3
Guru
Message 2 of 4
Re: Order details......
Have found a few users on incorrect packages or it's not registered about them being on the new Infinity speeds, wait until the install, if nothing happens, just simply upgrade over the phone. 150 should do the job!
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
iSean
Message 3 of 4
ahh ok. was a little confused when it said infinity 2 but those aren't infinity 2 speeds? I trust the guy who helped me on the phone more than teh site so I'll wait and see.
Thanks 🙂
Guru
Message 4 of 4
No problems buddy, hope it all goes well for you.
