Angela6
Message 1 of 6
Ordering new broad band cable - means of contacting BT
I need to order a new Broadband cable. Understandably phone lines are very busy this weekend. I have tried to ring several times, hung on for 10/15 minutes without a reply. Online chat doesn't seem to facilitate my request. Is there another way of contacting BT? Thank you
5 REPLIES 5
-Richie-
Guru
Message 2 of 6
Re: Ordering new broad band cable - means of contacting BT
What type of cable do you need ? Amazon sell ADSL and Ethernet cables for pennies, posted via Royal Mail will be with you in a few days.
licquorice
Message 3 of 6
Can you clarify what you mean by 'broadband cable'. If you just mean the cable that goes from your hub to the phone socket, you just need to order an RJ11 -RJ11 lead from Amazon. It is not something you can order from BT.
Angela6
Message 4 of 6
Thank you, for quick reply yes, it is the cable from the hub to the phone socket. I will order from Amazon.
Achildishperson12
Message 5 of 6
if  you can go on ebay and order one
 Much more better and less prone to interference  than the cheap flat cables they supply them selves.  Or you can buy this but a bit more expensive though
imjolly
Message 6 of 6
@Achildishperson12  You need to remove your eBay links as not permitted on forum
if not mods will
