Jervy25
Message 1 of 6
PING issues
I recently upgraded to BT infinity and I am finding my speed slower than ever to the point that I use my 4G more than WIFI. Ping speed is being blamed and I feel my hands are now tied as I cannot improve this in any way and BT obviously claim a high speed coming into my hub so not their issue.
5 REPLIES 5
Message 2 of 6
Re: PING issues
Wired or wireless connectivity,
Jervy25
Message 3 of 6
Re: PING issues
Wireless
Message 4 of 6
Re: PING issues
Therein probably lies your problem.
Can you try with a wired device to eliminate the actual broadband connection being the issue.
Jervy25
Message 5 of 6
Re: PING issues
I have checked with wired and does run better, not great though when most use is through phones which are never wired, I expected a faster wireless speed
Message 6 of 6
Re: PING issues
Wireless connectivity is very much situational and will be different in every house/area/situation as it is affected by many external factors of which no ISP have any control over
