Message 1 of 4
PON Flashing
Received an email from Openreach (OR) stating good news FTTP is now available at my address so booked an upgrade of my copper wire to 900mbps FTTP for 13May. Stayed home all day - OR engineer was a no show. BT rebooked me for 29 May am slot. Nice guy from Kelly Group arrived at 8am sharp and left by 10.30 having installed a new ONT box with two full green and one flashing green PON. Having removed my old copper connection he clearly stated I'll have my BB up and running again my midnight at the latest.
Today 11 June still no FTTP BB and still have a green flashing PON - BT have supplied me with a 20MBPS sim card however as EE signal is patchy in my area is not much good for TV. I have made repeated calls to BT only to be promised a call back in a couple of days time - to date not a single call back from BT however as the black CBT is outside my house a helpful OR engineer told me the problem appears to lie with the local exchange (about 1 mile away) and he does not have authorisation to enter the building.
Why on earth did Kelly engineer disconnect my copper BB before confirming FTTP was working correctly?
Help please what happens next?
3 REPLIES 3
Message 2 of 4
Re: PON Flashing
You report the fault to BT.
Flashing green PON means there is physical connectivity but your account hasn't been configured correctly.
Message 3 of 4
Re: PON Flashing
If you are the first connection on the CBT outside your house ( designed to serve you and your very near neighbours ) it’s possible that a records/data error is causing the issue (not in the exchange as your were told ) ….
The CBT outside your house goes back to a splitter and then back to the headend , if (for arguments sake ) the splitter node has 4 splitters in the same enclosure , and your CBT should be on splitter 1 but was incorrectly connected to splitter 2 , (this is easily done ) then the symptoms you have would be expected, PON light flashing as stated means ‘light’ is being received but the headend can’t authenticate the ONT , that is  because it was expected and entered into data that your address (via the CBT  ) was to be on splitter 1 and it’s not it’s on the wrong one , in this example number 2 …the good news , if the Kelly guy advised the ‘Tiger’ team , they should remotely be able to change the data in the headend for your address to splitter 2 ,so your  ONT can then be authenticated, otherwise it’s a physical change required in the splitter node putting thus error right  ….obviously this isn’t the only possible reason why your PON light is flashing but it’s a pretty common occurrence, once the data is corrected to match the physical setup , any other neighbour orders on your CBT won’t have the same problem as the data is corrected for all addresses on the CBT
Message 4 of 4
Re: PON Flashing
Yes I believe I may well be the first connection on the CBT however after another call to BT they have told me it's a "lighting issue" and the problem has now been escalated to an expert team - he stated "I will call me back in a couple of days with an update" - I don't feel very confident. Thanks for taking the time to give me a reasonable explanation and I will get back to BT
