Badabings
Message 1 of 2
PPOE timeout and smart hub showing amber light
Hello, hope you are all well.
For the last 2 hours or so, my BT Smart Hub has been showing a a steady amber light.
I went into the logs and it shows a PPOE error timeout since 12 midnight.
I tried turning it off and back on, but same thing with the amber light.
Also for some time now, the router seems to lose internet connection a few times a day.
But this now seems ‘constant’ and from looking at other community posts, it appears that this is an external problem at the exchange or something.
Please can a Mod assist me? Thank you.
1 REPLY 1
Oddius09
Message 2 of 2
Re: PPOE timeout and smart hub showing amber light
Tried a quiet line test 17070 option 2, any noise report as line fault.
Tried plugging into test socket, with the appropiate filter.
I had this issue recently turned out to be a lose connection at the telegraph pole.
