Stuartd
Message 11 of 37
Re: Pages not loading until refresh
I unplugged my Modem for about 5 minutes and it hasn't been around since, could be a coincidence however
Stuartd
Message 12 of 37
Spoke to soon still happening
Distinguished Guru
Message 13 of 37
Did you try changing the DNS yet?
If not, I'll try again 🙂
SteveBB
Message 14 of 37
I'm having the same issue. Google won't load until I refresh it, Twitch.TV images (not the streams, just the images) load extremely slowly. It has been sluggish for a few days.
tellboy
Message 15 of 37
Noticed it today myself.
Pages start to load showing the progress bar, then the progress bar stops and I have to refresh the page to make it load completely.
All the best
Distinguished Guru
Message 16 of 37
I'll take it the answer is "no".
The reason I ask is that I don't have the problem....
tellboy
Message 17 of 37
I have changed my Macbook Pro Network Settings to those you gave and the problem seems to have disppeared.
Will experiment with these settings an report back.
All the best
tellboy
Message 18 of 37
Google & OpenDNS did improve the situation but I am now back on the BT DNS and it seems OK today.
All the best
brebis
Message 19 of 37
I am new to Infinity (one week) and this is a constant problem, on all websites although also often on google mail. The url doesn't load properly and I need to either refresh, or call up the wireless settings and click that I want to join the BT home hub 4 network - whereupon it tells me that I am connected and the connection is fine.
 I lost data because of this, including my registration email address on Immobilise.com last night which is v annoying as it now won't let me continue as says that address is already registered (which it isn't, as pages refused to load).
I'm not tech minded and don't know how to change DNS settings and confused as to why I'd need to. All worked fine with previous ISP on 'normal' broadband.
I use a macbook pro, mostly on wireless as ethernet not really possible in my home set up.  Thanks for any help.
tellboy
Message 20 of 37
Here is a link to Apple's web site on how to change your DNS.
http://support.apple.com/kb/PH11162
Hers's how to do it specifically for OpenDNS
http://use.opendns.com/#mac
Here's how to do it for Google Public DNS
https://developers.google.com/speed/public-dns/docs/using
Let us know how you go on?
All the best
