tellboy
Message 21 of 37
Re: Pages not loading until refresh
@brebis wrote:
and confused as to why I'd need to.
It may only be a short term problem.
Here is an explanation of something called prefetching which can affect your page loading.
http://mac.tutsplus.com/tutorials/os-x/how-to-fix-slow-and-non-loading-webpages-in-safari/
I would be surprised if it didn't affect Windows as well but as you are using a MacBook Pro and I assumed Safari like me then this may give an explanation.
Also, my statement that mine was OK is false, it's playing up again.
All the best
tellboy
Message 22 of 37
For the technically minded I ran Google "namebench" on my Macbook Pro and here are the results:
namebench 1.3.1
BT-70 GB is 41.3% Faster than your current primary DNS server
Recommended configuration (fastest + nearest)
Primary Server
62.6.40.162
BT-70 GB
Secondary Server
194.72.9.34
BT 30 GB
Tertiary Server
194.73.82.242
BT-4 GB
Tested DNS Servers
IPDescr.HostnameAvg (ms)DiffMinMaxTONXNotes
62.6.40.162BT-70 GBindnsc70.bt.net61.6441.3%14.8897.703
194.72.9.34BT 30 GBbcn.customer.bt.net79.2210.0%14.01298.403
194.72.0.114BT-61 GBindnsc61.bt.net79.809.2%15.51517.603
192.168.1.254SYS-192.168.1.254BThomehub.home87.12 28.31305.403
156.154.70.1UltraDNSrdns1.ultradns.net96.73-9.9%16.63422.503
194.73.82.242BT-4 GBns4.bt.net113.92-23.5%14.53176.907
208.67.222.222OpenDNS-2resolver1.opendns.com124.05-29.8%15.92624.502
4.2.2.1Level 3/GTEIa.resolvers.level3.net198.55-56.1%14.93500.027
204.97.212.10Sprintlink-3ns3.sprintlink.net208.16-58.1%14.82681.607
216.146.35.35DynGuideresolver1.dyndnsinternetguide.com212.05-58.9%17.03500.023
8.8.4.4Google Public DNS-2google-public-dns-b.google.com534.79-83.7%25.13500.0327
Graphs
Mean Response DurationMean Duration Graph Fastest Individual Response DurationFastest Response Graph Response Distribution Chart (First 200ms) Response Distribution Chart (Full)
Query Details
View the details in Comma Separated Values (csv) format.
Configuration
NameValue
benchmark_thread_count2
health_thread_count40
health_timeout3.75
hide_results0
input_sourcealexa
num_servers11
ping_timeout0.5
psnsn_0_1286458
query_count250
run_count1
select_modeautomatic
templatehtml
timeout3.5
upload_results0
version1.3.1
Distinguished Guru
Message 23 of 37
Thanks. However, my experience tells me that BT DNS servers are best avoided.
If not, I'll try again 🙂
tellboy
Message 24 of 37
Interestingly though
Google is slower than OpenDNS
I presume the reason the BT DNS's are quicker is because they are local rather than worldwide.
All the best
Distinguished Guru
Message 25 of 37
It's no good being the fastest if they don't work 100%. Which they don't.
Far better to use ones that always work.
brebis
Message 26 of 37
Thanks for the suggestions. I've added Open DNS settings as suggested. Does it now default to them? I seem to have lost the HH4 setting now and I didn't write it down before adding the Open ones. Does that matter?
Too nervous to try anything re prefetching, but did read the mac article, thanks. It says don't attempt if you're clueless, which I am.
I'll check back here if it continues, or if there's any news on BT working on this issue. My download speed on speedtest is nearly 60mbps so it's doubly frustrating when pages don't load or take a minute to do so. Reminds me of the bad old days of dial up.
Yes, use mostly Safari but also FF and it's the same on both. Haven't tried Chrome.  And it's way worse on the iPad. So is the speed - 40meg as opposed to 60 on the macbook pro. Can I use Open DNS on the iPad and how? thank you!
Distinguished Guru
Message 27 of 37
Yes, you can use it on all your devices, it's in the network settings of the device.
brebis
Message 28 of 37
thanks
tellboy
Message 29 of 37
I have now tried all the suggestions on this thread plus I have removed the Flash plugin and the problem still exists.
It happens with BT DNS
It happens with Google DNS
It happens with OpenDNS
It happens with/without the flash plugin
It happens with/without prefetching enabled
I have restarted router(s), it still happens.
I have rebuilt caches, it still happens
I have done permissions repair, it still happens
I have zapped the pram, it still happens
I have reinstalled Safari, it still happens.
I am just about to apply Apple's last Combo Update to Mountain Lion to see if that works.
Has anyone solved it?
All the best
tellboy
Message 30 of 37
I am currently typing this with Firefox for Mac and it does not seem to have the problem.
Will keep testing.
