MahmudSiraj
Newbie
Message 1 of 3
Particular webpages taking a long time to load
Around 80% of the time webpages are loading fine but I'm experiencing frequent problems with a number if sites (outlook.com, google etc.) where the webpage won't load or it will take a long time to load. I've tried loading the pages on IE, Firefox and Chrome, I've cleared the cache on each broswer, cleared my dns cache and the problems still persists. Turning off the Homehub firewall fixed the problem but I don't want to keep the firewall off.
Any suggestions or advice much appreciated.
2 REPLIES 2
Message 2 of 3
Re: Particular webpages taking a long time to load
Try a factory reset of the homehub by pressing a pin into the recess button on the rear for about 20 second. This can often sort out configuration problems.
MahmudSiraj
Newbie
Message 3 of 3
Seems to have worked so far, I'll give it a few days to see if has solved the problem.
