59mhouse
Message 1 of 10
Paying for Infinity 2, receiving Infinity 1 speeds
Had BT Infinity 2 installed recently, a new line was NOT needed upon installation. We're recieving the below stats(attached pictures) on this line despite paying for Infinity 2. The results are the same at all times during the day/night, and were tested using a wired connection, as well as using the test socket on the faceplate.
Product name:
BT Hub 6A
Serial number:
+084317+NQ62374169
Firmware version:
SG4B100021F4
Firmware updated:
22/06/16
Board version:
1.0
Gui version:
1.28.3
DSL uptime:
0 Days, 3 Hours 30 Minutes 0 Seconds
Data rate:
19.35 kbps / 47.73 kbps
Maximum data rate:
19353 / 47621
Noise margin:
6 / 6.3
Line attenuation:
13
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
As you can see we're well below the guarenteed speed, as well as the speed for both range A and B on above.
Assuming theres nothing we can do from this end but it's down to BT?
Any help?
Cheers.
9 REPLIES 9
Message 2 of 10
Re: Paying for Infinity 2, receiving Infinity 1 speeds
Is your router connected to the master socket or an extension?
59mhouse
Message 3 of 10
Yep, in the master socket.
Message 4 of 10
Can you remove the face plate and connect to the test socket?
59mhouse
Message 5 of 10
Tried and tested.
Message 6 of 10
You need an engjneer visit
Joll001
Message 7 of 10
I am having the same issue and I am awaiting a reply from the complaints department (tried the online customer support and they couldn't help me and then sat waiting on the phone for ages for someone to actually answer - gave up in the end)....
59mhouse
Message 8 of 10
Anything I can do online to speed that process up? Or is it a case of phoning the support line multiple times.
59mhouse
Message 9 of 10
We've now noticed that we have a 3M Waterproof Telephone or Data Cable Joint connected across the length of cable running from our premises. The wires inside are thrown together, and both come out the same side of the joint. Is this likely to be causing the issue?
Message 10 of 10
Without an engineer visit it will be pure guess work.
