Message 1 of 1
Periodic spikes and network drops
Hi there,
Firt off my setup:
Line comes in -> BT Home Hub 5 Type A (Software version 4.7.5.1.83.8.236.1.2 | Last updated 15/07/17) -> (1) Ethernet out to sonos controller (2) Ethernet out to netgear switch <- All other devices connected to the switch
I have been experiencing issues with my network connection on my home network. Periodically (every 3-20 minutes) I will experience spikes of lag when using VOIP such as discord or teamspeak as well as in game. (Note this is on a wired connection)
On top of this, less frequently however, the network drops completely and the power light turns solid orange with no other indication light showing (e.g. the broadband light).
I have already contacted BT and they have done line tests stating that they are all good and that it is something wrong with our home network.
Couple of things I have tried already:
-Power cycling the router
-Disconnecting my synology box
-Disconnecting my wifi range extenders
Any suggestions would be appreciated,
