pompey1898
Recognised Expert
Message 1 of 50
Persisten disconnects
Hi @RobbieMac & @PaddyB,
Further to my last complaint on this subject :-
https://community.bt.com/t5/BT-Fibre-broadband/Persistent-disconnects/td-p/1903288/page/5
Ever since then I have continued to suffer daily, or more, disconnects.  It has not escaped my notice that the mods are providing assitance for some people that are only getting disconnects every 2 or 3 days.  Since the vast majority of my disconnects are at night I have not complained again - TILL NOW !
Today I have suffered 3 disconnects, one of which was during a session with HMRC that then required the complicated log-in process for a second time, which left me furious.
So I can I beg you to investigate again please ?
49 REPLIES 49
pippincp
Sage
Message 2 of 50
Re: Persisten disconnects
According to the thread you refer to everything was acceptable.2019-05-02 16_55_45-Solved_ Persistent disconnects - Page 5 - BT Community.png
pompey1898
Recognised Expert
Message 3 of 50
Hi @pippincp ,
It was at the time I posted that, 14 days between disconnects was totally acceptable.
However, things have got worse again hence my request for the mods to investigate.
pippincp
Sage
Message 4 of 50
Fair enough so it is a new fault, you know the drill.
Router stats, test socket and quiet line test.
pompey1898
Recognised Expert
Message 5 of 50
I hear what you say but is hardly a NEW fault, it is a fault I have lived with for over 10 months.
pompey1898
Recognised Expert
Message 6 of 50
Hi @pippincp ,
Router stats :-
Quiet line test is silent.
Can't use test socket.
Since posting here yesterday I have lost connection 4 times.  2 showed in the hub stats as the router disconnected but I don't know what caused the other 2 as there is nothing in the log and the router remained blue.
Hope this helps you and the mods.
pippincp
Sage
Message 7 of 50
The router stats would be more helpful than the status page.
pompey1898
Recognised Expert
Message 8 of 50
Hi @pippincp ,
Sorry about that.  Is this what you want :-
imjolly
Message 9 of 50
why can't you use test socket   I checked back though old posts but couldn't find the reason you are unable to use test socket
pompey1898
Recognised Expert
Message 10 of 50
Hi @pippincp ,
When I had problems, I think it was last May/June, the last engineer went through everything with a fine toothed comb and moved the master socket to the hall, mainly so the engineers had better access.  He then made a coonection through the wall to where the old master socket was and where the router is located, see picture below :-
